Printer does not respond, and we restarted it and it still does the same thing
    Novelist:
  • 125 Answers
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Posted on Aug 18, 2008
  • Josh Gahan
    Josh Gahan Aug 18, 2008
    oops it should look more like this sorry about the confusion but Fixya doesn't let you edit your own comments:
The printer cable is not recognising by my computer...
Here are a few things you can try,
Unplug and replug the USB cable. (I'm sure you tried this.. Lol.)
Try another USB slot on your computer.
Restart your computer and try it again.
If the USB cable can detach from the printer, check if it's loose.
Find the printer software on the Internet and download it there instead.
If those things to solve the problem, consider that the printer may just be broken..
Aug 17, 2016 | Canon LASER SHOT LBP-2900 Printer
Printer Stopped Responding
See if you can order a new power supply unit for it. The service manual is here: http://servicerepairmanuals.net/printers/samsung-scx-4725fn-digital-laser-mfp-service-manual/ I dont know if you want to go this far into it though.
Jan 19, 2014 | Samsung SCX-4725FN All-In-One Laser...
My scanner is plugged in but when I try to scan a document it says my scanner is not responding
If it is your first time using your printer, then you need to install the driver for it to work.
If you have used your printer without any problem before then, there are two possible reasons why your printer/scanner is having that issue:
1. Connection error
2. Driver problem
First thing's first. Restart your computer and your printer. there are times that computers and printers just need a restart for it to work. Yes, it's strange but it's how things work with machines. They need rebooting to work smoothly.
If rebooting your computer and printer won't fix the problem. Here are the things that you can do.
1. Connection error:
a. Turn off your printer and turn it back on. Try scanning, if no go.. proceed to step b.
b. Unplug your printer from your computer and unplug it's power cord and press and hold the printer's power button to 5-8 seconds to completely drain the power. Plug it back in to the wall outlet leaving the connection between your computer and the printer still unplugged. wait until your printer completely turns on. Plug it to your computer and do the scanning process.
If all steps above don't work, then you need to check the driver.
Uinstall the driver of your computer by going to the control panel. After uinstalling it, then reinstall it by using the dvd that came with your printer. Follow the on-screen instructions and try scanning. It should work.
If it doesn't, please reply to this thread.
Thank you for using fixya.com
Carlo Adrian
Nov 14, 2012 | Dell Photo 926 All-in-One Printer
My cannon mx410 printer is not responding. We have unistalled and reinstalled 2 times and nothing. Help, please.
reboot both pc and printer, you reinstalled printer drivers?, try restarting your print spooler service, try on another machine to confirm where the problem is with pc or printer.
Oct 09, 2012 | Canon Pixma MX410 All-In-One Printer
When i try to print doesn't print and message shows in upper bule line'usb port not responding" what should I do?'
If you are using Windows Operating System, I suggest you do the following procedures.
  1. While your computer is turned OFF, unplug the printer's USB cable from the computer and transfer it to another USB port in your computer that is unused.
  2. Then turn your computer ON and Windows will try to configure it and install the drivers needed for your printer to run on the new USB port.
  3. If steps 1 and 2 above don't work to fix your problem, the last thing I can recommend is "uninstall" your printer from the Control Panel and restart your computer. After restarting, install your printer and try if it now works.
Jun 08, 2010 | Dell 924 All-in-One InkJet Printer
My canon MP610 printer is not responding after replacing ink
Try switch of computer and printer if not in printer list of printers. Unplug usb cable and start computer without computer connected. Them switch off computer again and plug in usb cable and then restart and after started switch on printer and Windows should find printer as a new connection and then you may need your driver disc to reset up.
Mar 17, 2009 | Canon PIXMA MP610 InkJet Printer
Printer does not respond, and we restarted it and it still does the same thing When I click the print command on my computer, the printer does not respond.
Try reinstalling driver, change the data cable between the printer and the computer...
Hold down the paper feed button while turning it on (or the change ink button) and it should print a self test...
for info on self test instructions let me know the printer make and model...
Matt
Jan 21, 2009 | Office Equipment & Supplies
Xante Accel-a-writer 3N Printer Not responding
I just signed up today. Are you still having the responding
issue?
Dec 18, 2008 | Xante Accel-a-Writer 3N Laser Printer
Printer not responding...
try to check your setting for the printer before printing. maybe you have paper jam try to check feed papers. press the power if this is blinking. If the problem persist just restart your computer. Sometimes thist problem needs restart to continue printing.
Nov 07, 2008 | Microsoft Office Professional 2007 Full...
918 people viewed this question
jasbo
jasbo
