Question about ASUS Computers & Internet
Want to change the picture that comes on at startup on my asusP5K/EPU series mobo
    President:
  • 2,961 Answers
You cannot change the picture, only dissable it in the bios settings.
Posted on Aug 18, 2008
6ya staff
SOURCE:
Need replacement steam wand wega epu 2
wega epu. Commercial machine. I'd check espressoparts.com. Any faema, wega, nouva simonelli wand will screw into the wega valve.
They also have precision wands from japan. Sproline series i believe it is called.
I have no association with the site but i do know that any of the parts Listed will work.
Oct 04, 2013 | Wega Coffee Makers & Espresso Machines
Asus mobo flashes on startup, no video
You should unplug the power cord from the power supply, pop out the cmos battery, switch the bios reset jumper to the 2 and 3 pins, wait about a minute, put the jumper back to 1 and 2 pins, put cmos battery back in, plug in power cord to psu and turn on pc. If you have any issues with this process please refer to your owner manual for the motherboard or look one up on their website. Please let me know if this fixes your issue.
Apr 30, 2010 | ASUS M4A77TD Motherboard
Miniwx epu no water coming from group head to cup no water at cylinoid
Since there is no water at the solenoid, then the blockage must be at the metering jet, which sits under the nut on top of the group, turn of water supply and be careful when removing nut do not damaged o-ring if it is not a teflon O-ring, you might have a leak. Clean out jet and filter then reassemble.
Apr 17, 2010 | Wega Mininova EPU Espresso Machine
No signal to monitor.
try to put a pci-e video card series 9600 geforce or ati
Mar 03, 2010 | ASUS SKT-775 P5QL/EPU S/L 1333FSB...
My computer is powering on but it isn't booting up.
You can check your BIOS at startup. Right after the Beep press F2. sometimes it's a different key depending on the mobo. Change the boot order so your CD or DVD device is read before the hard drive. That way you can put in your linux boot disc, (or M$ Windoze)and boot from that disc.
If there is an error there will be a series of beeps. Those different beeps mean different things, check your motherboard manual onlineif you don't have a manual to see what's not detecting. Either graphic card, memory, keyboard, etc. Hope this helps you out
Oct 19, 2009 | NZXT Apollo
Pump problem
Do you have a manometer on the machine and if yes, what is the reading when you are pulling a shot, does the gauge move, have you opened the side of the machine to see if the pump is turning, you might have to adjust the pressure on the pump by using the adjusting nut instead of replacing the whole thing.
Jan 10, 2009 | Wega Mininova EPU Espresso Machine
Cannot access bios or find c:\ drive model Freevents X56 windows XP media center edition 2005
If you wish to change some setting in BIOS, you can try the alternative method to access its properties.
Go to Start --> Open Run --> Type in msconfig
Here you can change the boot timing and Normal, Selective or Diagnostic Startup.
Also disable the startup applications. For BIOS go to update as per your Motherboard and Computer configuration from Microsoft website and MoBo Website.
Dec 07, 2008 | Computers & Internet
Memory Issue
yeah you should upgrade. Windows xp 32bit only support up to 3gb memory. You should upgrade to 64bit.
And your specs? Yeah it can run 64 bit operating systems or if you like, use Windows Vista x86 or x64 with Service Pack 1.
Sep 24, 2008 | Microsoft Windows XP Professional x64...
Dell Inspiron 1100 startup
bad battery bad mobo bad power chips on the mobo tuff one bestto sell for parts on ebay if u dont know how to change
Jan 15, 2008 | Dell Inspiron 1100 Notebook
Open Questions:
Computers & Internet Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
