BEHRINGER 602a MIXER..HOW CAN I USE
A CRATE GUITAR VAMP HEAD WITH THIS MIXER, HOW TO HOIOK UP
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi drtele
    A couple of questions to clarify what you want to do first,
    1. Is it a V-amp you have, or a Crate Amp head?
    2. do you have a speaker box?
    3. are you trying to record?
    Please let me know and I can give you some advice.
    regards
    robotek
  • 1,512 Answers
Hi, still looking for help on this one? Happy to assist
regards
robotek
Posted on Sep 06, 2008
X-vamp pedal only makes feedback noise
Try changing the configurations to your desired effect.
Dec 24, 2011 | Behringer Lx1x X Vamp Amp Multieffects...
How do you connect a Boss ME-70 pedal to this mixer.
Since the pedal is for one instrument only, your guitar should go through it and a Balanced TRS cable should go from the pedal to one of the 1/4 inch LINE inputs on the mixer.
Jan 23, 2011 | Behringer XENYX 2442FX Mixer
I need to know which pin is the live and neutral for a behringer dx 1000 pro mixer
On the power line cord the neutral usually has a wider blade. Also the cord MAY have ribs on the side of the neutral conductor. The polarity of this cord is NOT important to the operation... the power supply does NOT care.
If you are asking about the cord that goes from the power supply to the mixer, then we need to talk further. This three wire connector has a ground and two 19 VAC hots. Describing the pins in the triangular pattern would be risky... HOWEVER you can use an ohmeter to find the single ground by looking for near zero ohms on one and only pins of the mixer to a ground on one of the 1/4 inch jacks. The dual 19 VAC power supply is rated at 1.5 Amps (1500ma) for each of the 19 VAC outs.
Note these 19 Volt hots come from either side of a 38 volt centertapped transformer with the centertap to the ground.
Dec 24, 2010 | Behringer VAmp 2 Power Supply
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
XENYX 1222FX Mixer
I've had the same problem. It just is like the tracks mix up with each other. It's pretty irritation when you come to the mixing process. You just can't mix track where the first one for example actually is some song. But you also got some guitar from track 2 on it and the guitar track has got track 3 and 4 on it and so on and so on.
How do you fix that problem
May 22, 2008 | Behringer Dual Engine 24 Bit Multieffects...
115 people viewed this question
 Grubhead
Grubhead
