Question about Kodak EASYSHARE 5100 All-In-One Printer
Printer problems i have a problem with my printer. It won't print anything on the paper. It sounds like that it is printing, but the page comes out blank
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Ok..can you run a test page first?
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I have a hp officejet printer hooked up to my daughters windows xp. It is installed and when you click on print it printing but it will not print. All the lights are flashing on the top.
Well here is the resolution for the problem.
As you had mentioned that the printer prints on given command print but the print outs are not coming out of it.
Well sometimes even if you had not set the papers in tray properly than also it wont take paper to print out.
It will sound like its printing but the paper is not getting in. So please check the paper tray if it is not set properly please set it or even the pages you used in it are in proper order or not even check that as well.
Well sometimes If the printer run out of cartridge than also it wont print anything even it insert the page ven it will come out as blank as it was inserted, So please check if your not run out of cartridge if so please change it and your printer will start working again.
Please do reply me if you still have the same problem or any more problem.
Naiven.
May 21, 2010 | Office Equipment & Supplies
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
Printing Problem
My first copy comes perfect second copy the yellow color is getting shake
Nov 20, 2008 | Xerox DocuColor 12 Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Printer does not print
Change the paper type to anything other than plain paper. It works but I do not know why.
Sep 10, 2008 | Canon i850 InkJet Photo Printer
My 6200 Lexark will only print the first part of a page (approx.30-40%) then the paper comes out. The printer counter then goes to l00% but does not print anything else.
Sounds like you may have the wrong driver installed, does it do this with any type of printing (pictures, letters, web pages, etc.)?
Aug 02, 2008 | Lexmark Office Equipment & Supplies
Kodak EASYSHARE 5100 All-In-One Printer Logo
89 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
