Question about Intel Motherboard
Hi Benimur Hi My system is also restarting alternately. when i use my first ram slot the system will restart every 20min, when i using the second slot it will restarting every 5min .
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
To your concern, initially pls try:
  • remove the memory sticks;
  • clean both slots with a clean dry toothbrush/paintbrush. You could also use a can of compressed air or an electronic contact cleaner spray;
  • clean the little gold pins of the memory using a pencil eraser.
  • If the above is not sufficient to address the issue, pls try resetting your CMOS/BIOS to default condition.
This is of course assuming that there is no hardware fault.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
System getting restart automatically
Yes, try to clean RAM and change its slot.
You can also check running chkdsk from recovery console using OS bootable CD.
Dec 13, 2011 | Intel DG31PR Motherboard
I'm using DG31pr motherboard with intel core2duo processor,, my pc is not starting when i restarted it... the red led is not turning on after restarting the pc & 3beep sounds are coming frm board and...
I think this is due to dust inside the PC
Try the following
  1. Check that all the fans are working
  2. Take out the RAM and clean the RAM and the RAM slot and intall it back
  3. Clean the IDE connector that connects the Harddisk to the Motherboard
this should solve your problem
Feb 26, 2011 | Intel DG31PR Motherboard
Hey, the computer starts with no beep or continuous beep. thanks
May be the RAM Problem
For solving the problem do the following:
1. Remove the RAM(s) from its positions / place from the mother board
2. Clean the RAM slots inside the mother board with a neat and dry brush
3. Rub the "RAM (Copper Bottom) with an eraser or with hands gently for a few seconds.
4. Place the RAM in their slots and restart the system
Let me know! that i Fixya the problem
Thanking you.
B.Krishnamacharyulu
Nov 08, 2010 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
System won't start, power retries every 1-2 seconds
Make sure your smps power supply of cpu is working fine.
Make sure motherboard is not ground with cabinet cover.
Pull cmos cell from motherboard for 10 minutes then put it into it's position.
reattach the RAM memory into slot also make sure ram is fine.
Clean dust from all parts.
Reattach processor and it's fan.
Reconnect pci card or vga card if any.Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 03, 2010 | Intel Motherboard
Motherboard boot problem
try resetting to bios defaults.
Also if your using dual-channel memory modules, ensure it,s enabled in the bios setup.
alternatively, try ram in different slots.
Thankyou for using Fixya.
mike @ compurepair.
Nov 19, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
DG965RY board can not reboot with 'restart' button on windows Xp
Run with only two RAMS each in one of the DIMM slots. Three RAMS may not work unless supported by mobo or being exactly identical in their specs..
Nov 17, 2008 | Intel DG965RY Motherboard
Hi - benimur
Pls check:
  • if CPU heatsink fan turning;
  • if heatsink is flat on CPU and tight;
  • if PSU exhaust fan turning;
  • if Video Card heatsink fan turning;
  • with a voltmeter, pls check consistency of the yellow and red wires (+12 and +5);
  • pls inspect capacitors near the CPU, none should be blistered, bulging are leaking;
  • remove the HDD connection and observe it will restart, if no, then probably a driver/software issue.
Aug 18, 2008 | Intel Motherboard
Still a problem
the blue screen flash and restard is actually a critical system message, but windows is set to restsrt the system on a system failure, if you want to read the message, start the computer and tap the "F8" key until a menu appears, one of the options will be "disable automatic restart on system failure" select this option and the next time it happens it will stay there.. but from what you are describing it is pretty evident you have bad ram, the long beeps you are hearing is the mainboard signalling a critical error, usually caused by ram, get new ram and i think you will have no problems
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
No display
Dear hubult,
There is issue with u RAM because when u remove the RAM it starterd beep it means u r RAM slot is ok. the problem is with u RAM pls change the RAM and then check it and one more thing before u change the RAM do one thing take out the CMOS battery and then restart the system after restarting the system shut down the system and then reconect the CMOS battery and start the system.
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
Various Corrupt Messages on Blue Screen (windows XP Pro SP2)
Hi, in my repair workshop I have seen this problem several times and almost always it is a problem with blown capacitors on the mobo. When you have the case open again inspect the capacitors, [they are the round objects grouped together in lots of 5/6 on your bourd] If any show signs of bulging at the top or leakage from the bottom, unfortunately its time to replace the mobo. This can be fixed but the labour cost will almost equal a new board. Goodluck mistyman
Sep 21, 2007 | Computers & Internet
Intel Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
