Question about Samsung Computers & Internet
52-32-52 CD Internal Drive Tray Opening And Closing Problems
The CD Rom tray will not open or close properly. When there is no disc in the drive I always have to insert the emergency pin to open the tray. After I load a disc the tray it will not close properly. It seems to try to close, but I have to tap it to close. Often, it closes 1/2 way and stops. Sometimes, it tries to close and then reopens. Sometimes it does nothing. When I finally get the drive closed it plays ok. Can I fix the problem myself?
Myles Harmon (myles260@ispx.com.ph)
I followed the instructions given me to open up the CD drive. There I found an accumulation of oily dust that had settled on the gear and on the micro switch. I carefully, thoroughly and gently cleaned the parts with a soft brush, alcohol and canned compressed air. I examined the rubber drive band and it did not look badly deformed. I reassembled the case, put it back in the computer and it is working fine for now.
Posted on Aug 19, 2008
    Brigadier General:
  • 6,966 Answers
Since the CD drive still reads the disc, then repairing the unit is to your advantage. Repair involves, removing the drive from the desktop and removing the 4 screws underneath. The two halves/covers could now be separated and removed. Under the tray would be a gear mechanism that slides the tray in/out. it is powered by a motor through a small rubber belt. It is likely that the belt has deformed and would require replacement. This belt is similar to those used in audio electronic equipment and therefore would normally be available from your friendly neighborhood electronics parts store.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
Artec wsm-52x Problem...My CDROM drive keeps opening and closing. I tried disabling it in Device Mgr, but the problem still exists. I also uninstalled it in Device Mgr, but still it keeps opening and...
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 11, 2011 | Artec WSM-52X-UR CD-RW Burner
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
Cd drive opening and closing on its own
You never should have pried it open. Only use the manual eject pin-hole with a paperclip. Noe it seems the drive tray is damaged and will not close properly so it is constantly opening and closing trying to find home. The drive will need replaced.
Jan 02, 2009 | Dell INSPIRON 6000 CENTRINO...
Ddvd drive struck and not closing
if dvd struck or locked inside you can try use pin paper to open drive cd you can see a smart hole inside DVD drive so just put it the pin so you can open the drive
Jul 20, 2008 | Dell Inspiron 6400 Notebook
Cd rom
its very simple .remove the outer cpu case.then remove the cd rom open itplace THE TRAY in RIGHT MANNER ONCE AGAIN . donot try to move the tray of your cd rom without opening the cd rom ,it might result in a permanent damage
Nov 03, 2007 | Packard Bell GCD-R580B (gcdr580b) Internal...
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Computers & Internet Logo
380 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
