Question about Apple iPhone 3G
I phone cant detect
My i phone cant detect and when on the screen black like dos mode and then hang. no menu, nothing shown.
  • don78 Aug 24, 2008
    my iphone can't detect by the itunes, it just that i updated it by the new firmware 2.0.2 then t'was frozen till now, there's nothing you can see in the screen but the apple logo.. both my 2g & 3g..
Use ibricker to get out of DFU mode or ziphone if it doesnt work put it in DFU yourself and restore
Posted on Aug 28, 2008
Finger print lock is on cant get innto phone because i forgot password
Hard Reset Phone. Only all info is erased.
hold vol up key + home key (if a hard button) +power on key. Hold until DOS Menu appears.
Black screen with green letters.
Use vol up and down to scroll
power button for okay.
click reset manufacture settings.
Mar 26, 2017 | Cell Phones
HOW CAN IT BE FIXED? CAN IT BE DONE ONLINE?
Have you tried doing a factory restore? It will wipe all the information from your phone(contacts, downloaded apps, etc) most likely this well solve your problem it sounds like the android os is not booting properly or may have a system dependent service crashing on boot causing the system to hang. With the phone off press and hold the power button and the vol down button(might be volume up button) should get you into recovery mode where you can do a factory reset.
Apr 24, 2014 | Kyocera Event Black Smartphone AA€A Virgin...
How to turn off dos mode
go to start up menu OR totally shut down PC then On ... when DOS --screen appears click stop screen then DOS MODE
Jan 24, 2014 | Computers & Internet
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Dell wont open windows in start safe mode
You need to run the check disk utility. You have corrupt or missing boot or system files.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 13, 2012 | Dell Latitude D830 Intel Core 2 Duo T7250...
My computer cant detect my iphone4 when its plugged in and it wont turn on or charge
Once you upgrade the firmware. You can not go back. To bring the phone back at least from black screen. You have to keep trying to reboot in dfu mode.I am assuming you jail broke your phone, so you might have to use that software to bring it back up with that.Good Luck
Nov 24, 2011 | Apple iPhone 4 Black Smartphone
When I make a phone call the screen goes black and you cant bring the screen back up until the other person hangs up
A few things to check:
1. If it worked before and not now then it is possibly an app on the phone that is interfering with the call some how.
2. Their is a photo sensitive device on the phone put their to detect the presences of your face when your making a call. It often looks like a black circle under the plastic or glass surface of the phone. Make sure it is clear so that light may pass into the devices chamber (make sure their is no dirt or oil on it).
3. Also try to update the software on your phone. You can usually find an check for updates option under the settings on the phone.
4. If all else fails try to reset your phone to factor defaults. However this may erase data on your phone.
5. If nothing else works then it sounds like a software glitch that a developer would have to fix.
Mar 15, 2011 | HTC Aria Cell Phone
Hi when i reset my i phone 3 5 it only shows apple sign and when connected to comp it doesnot show i tunes
You will probably need to reboot into recovery mode and restore your phone. To get into recovery mode, make sure your phone is connected to you computer via usb cable, then you need to hold down the sleep button and the home button down at the same time for 10 seconds then release the sleep button. Continue holding the home button down until iTunes detects a phone in recovery mode, once it's in recovery mode you can press the restore from within iTunes.
Mar 02, 2011 | Apple iPhone 3G Black Smartphone
Have a brand new camera, and the screen stays black, even though the control info is shown
If you mean the menu info is shown but not the picture you want to take, just press the "menu" button again to return to picture mode.
Jan 07, 2011 | Olympus PEN EPL1 Digital Camera
Iphone-hang
just press the power botton + menu botton for a few seconds, it will restart and you will see the apple logo press menu again after 3 seconds and it will come back to life
Mar 19, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
51 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
