My computer doesn't have sound, i might have erased something on accedent please help me
    President:
  • 2,961 Answers
Go to start>programmes>accesories>system restore, then restore your system to a date before you had the problem.
Posted on Aug 18, 2008
Power Doesn't Turn The Computer On
Well if isn't the power supply or the motherboard, it's a boat anchor. You can still use the TX certified sound card in a new one.
Feb 10, 2013 | Dell Dimension 8200 PC Desktop
Monitor dont works
Buzzer 3 times from buzzer component on motherboard, not from the Processor.
Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Buzzing, or beeps actually, that you hear are BIOS Beep Codes. The computer's way of telling you something is wrong, and an area to look into for it.
3 beeps generally means a problem with the Ram Memory.
Computer unplugged from power, Anti-Static Precautions FOLLOWED, suggest removing all Ram Memory module/s ('Stick'), and clean the gold plated contact pins with a pencil eraser.
1) Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
2) http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
[You can click on the photo to enlarge ]
If you are using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band on the pencil, touch the gold plated contact pins.
Everywhere on the Ram Memory module EXCEPT the gold plated contact pins at the bottom; is the BODY.
The Body is coated with a see-through protective plastic.
Handle the Ram Memory module by the Body.
Rub up, and down on each gold plated contact pin. BOTH sides.
Doesn't take much pressure, nor rubbing to clean a contact.
(Maybe 6 to 8 times up, and down)
In fact when you are done, the contact pins may not look bright, and shiny.
They are clean I assure you. Doesn't take much 'corrosion' to make a bad contact surface. (Gold isn't supposed to corrode)
Use air to remove the eraser dust. If you have a can of compressed air available use it. If not air pressure from your mouth will be sufficient.
If the air is available use it to clean out the Ram Memory slots also.
Reinstall all Ram Memory modules.
(Make sure they are seated tight, and locked in)
Make sure the inside of the computer is clean, and to include the inside of the unplugged from power Power Supply, the best that you can.
Post back in a Comment as to your findings afterward.
Regards,
joecoolvette
Oct 08, 2012 | Dell Computers & Internet
My computer is infected
Well that sounds like you got a virus disguised as an antivirus, those are pretty common, in that case you can erase it, but the slow load on your computer will remain, if you get a virus usually there is a way to delete them but the consequences will remain, in that case you can reinstall windows, that will be better that just removing that virus, Best regards, Luis!
Jan 24, 2012 | Computers & Internet
I recently did a dry erase on my computer but now I can't get any sound
dry erase??never heard of this expression before ,if its what i suspect that formatted the hard drive and re-installed the windows programme then yes you will need the original boot up disk to install the sound drivers .
Dec 02, 2011 | eMachines T Computers & Internet
By mistace i erase sound driver or something alls
look there is a code in the mother board please enter this code and search for the driver in the internet or please give the number ,i will find out the driver for you.
Oct 17, 2010 | Computers & Internet
IN ACCEDENTLY REMOVED THE DRIVER FOR MY MULTIMDIA AUDIO CONTROLLER AND NOW I HAVE NO SOUND WHAT CAN I DO
If you have a dell computer, you can go to their website at http://support.dell.com/support/downloads/index.aspx (just click here)
find your model or enter your details, as required to get to the software and downloads, find the audio drivers download the file and install it. probably just double click on the downloaded file.
Oct 14, 2009 | Dell Dimension 2350 PC Desktop
No Sound!
Well BeatLa..
You can get the driver from here:
http://ftp.us.dell.com/audio/R94481.EXE
Give it a try, and let me know.
Jul 04, 2008 | Computers & Internet
No Sound!
Here is the download page for the Dimension 3000 (Windows XP): http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=DIM_CEL_3000&os=WW1&osl=EN Go to the audio driver page and assuming you have the built-in audio card this should take care of you. If you by chance have some other operating system here is the link that will allow you to select the correct one. http://support.dell.com/support/downloads/index.aspx?
Dec 09, 2006 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
794 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
