Question about HP LaserJet P2015n Printer
HP LaserJet P2015n Printer IP adress
My printer is connecting to network, but it change it IP every time
the problem that it get zero IP adress ,how to reset it???
  • Anonymous Oct 14, 2008
    i had it on my network at work and now i dont have it on my network and im not sure what IP address it had
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Posted on Sep 23, 2008
SOURCE:
HP LASERJET M1005 MFP IP adress
How do you have it connected to your network? Its IP address will depend on what subnet your LAN is (example: 192.168.1.x).
You can download Advanced IP Scanner and look for your HP printer in the list of devices scanned on your network. Or you can go to HP's site and review the official documentation.
HP LaserJet M1005 Multifunction Printer series
Jul 30, 2016 | HP LaserJet M1005 MFP Printer
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
Hp p2015. my ip has become 0.0.0.0, how do i reset it
To configure this model HP Laser as a network printer, please click on this link and follow my instructions ;-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
May 19, 2011 | HP LaserJet P2015n Printer
My HP P2015n won't connect properly to my home network
I'm afraid the formatter pcb is defect. You will have to replace it. Partnumber Q7805-69003.
Feb 14, 2010 | HP LaserJet P2015n Printer
I have a HP LJ P2015n. Should be on our network
As i understand your concern you have network printer which you want to setup with your network. And right now your printer is connected with the computer using a usb be cable. Thats the main reason why it is having different ip address because it don't required any ip address once you tried to connect your printer through usb cable. I can suggest you that once you connect your printer on the network and you will get the option to network setup on your printer where you can assigned static ip to you printer which is the range for your router or network device called DHCP.
I believe that will help your resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Oct 28, 2009 | HP LaserJet P2015dn Printer
Printer hp laserjet p2015n
laser unit mirror is dirty clean it than solve it
May 29, 2009 | HP LaserJet P2015dn Printer
The HP Laserjet P2015N is showing an IP address of 0.0.0.0 it is set to pick up an IP address fron DHCP but it is not. I have tried Factory Rest and normal cold rest. Any ideas? Also we have a few of these...
the printer will only show the 0.0.0.0 IP-address when he cannot contact the DHCP server. check your physical network connection (see if the leds next to the network port on the printer are lit or flickering) and the DHCP config for this printer. if you work with a manual DHCP, you need to enter the printer's MAC address in the DHCP-entry for this printer.
May 07, 2009 | HP LaserJet P2015n Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015n Printer Logo
2,614 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
