Question about Kyocera Mita FS-1920 Laser Printer
Change cartridge's instrutions for kyocera FS1920
Hi im trying to change my cartridge i have a Kyocrea FS1920 do you have the insturtion's for this as the one's in the box have been thrown out>?
Hi
To replace the toner in the Kyo fs 1920 you have to open the top cover, under you will se a small blue clip in the upper right section, you have to pull that to the right, it will release the the toner box what is the big black pice under the to cover. After removing the toner box place the new toner box in the right direction (if you are in front of the printer, you can read the text on the top of it) and push it gently down. You should hear a click and you can see the movement of the light blue clip. Ps.: don't forget to remove the orange pieces from the new toner box befor installing.
Posted on Oct 15, 2008
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
FS1920 says "processing"
Hi
It would appear that there is a problem during translation from the document to the printer. The following procedure may help:-
Try turning off the printer, on the computer clear the pending jobs for the printer until none are left. Turn off the computer and wait for 30 seconds. Turn on the computer and wait until it is fully booted. Again check the printer queue is empty. If it is not clear it by deleting the pending documents again and then reboot again. Repeat if and as necessary until the printer queue is and remains empty. Restart the printer and again wait until it is fully booted. Hopefully this will have cleared the error and you can start printing again. Start with something small and simple so that you are not putting a significant processing load on either machine.
I give below a link from which the manuals for this machine may be downloaded. If the above procedure doesn't work there may be something in the manuals that will.
Download Center
Good Luck
Nov 09, 2014 | Kyocera Office Equipment & Supplies
Fs 1920 service 1200
your du-61 duplex unit is faulty or not installed correctly check the harness and gates if all this is ok its the engine pwb has failed
Feb 17, 2014 | Kyocera Mita Office Equipment & Supplies
How to add fs-1920 printer to HP300 pc
depending on u're OS you can use a wizard from printer and faxes for win xp and win7 or using installation cd. connect the usb cable or parralel cable switch on the printer the found new hardware appears continue with installation select u're model kyocera->fs1920 or nearest model-> then follow instructions
Jun 22, 2012 | Kyocera Mita FS-1920 Laser Printer
By Kyocera Mita FS-1020D printer has had it cartridge changed and his just printing a grey smear on the paper and no readable information
is the cartridge a genuine Kyocera cartridge? I had similar problems on some models with the cheaper generic products. had to strip and clean the whole process unit to rectify the problem.
Jan 14, 2011 | Kyocera Mita FS-1020D Laser Printer
How do I find ESN/MEID on Kyocera K323?
Your esn/meid is on a sticker under the battery of your phone. if the sticker is missing let me know and i will give you instrutions on how to pull it up.
Nov 20, 2009 | Kyocera Verizon Wireless K323 Cellular...
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Nov 08, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
119 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
