When I copy on my printer the white paper comes out blue. The paper for this is plain paper. This only happens when I am copy not when I am printing. Also if I copy a Picture I only get a blue line that runes down one side this is using photo paper
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple...
(More)
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple of days ago. Test pages print fine from the print controller.
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has...
(More)
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has never been used for scanning
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink....
(More)
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink. How can I select "print in black only?"
