Question about Mercury P4VM800M7 Motherboard
IDE solt promblem
Hello, my motherboard is not identifying hard disk, it is showing disk failure. if i identify hard disk it will not identify cd rom either of one will work what is the problem plz give me solution.
I have mercury board (pvm890m) but i can't play sound in vista o/s system plz help me out. thanks vivek
Posted on Aug 18, 2008
Dont know where to plug in cd drive
You have to identify first what kind of interface your CD-ROM uses. This can either be IDE or SATA.
Note that for IDE interface, there is a master/slave/cs settings for the device. If you are using one cable to connect the hard disk and the CDROM,make sure that the settings for the hard disk is set to master and CDROM to slave. If the IDE cable you are using has a twist on it, then both device should be set to CS (Cable select)
For SATA, this is just point to point. Please check below link for more details.
http://it.flexinet.com.au/bits%20and%20pieces/HARDDRIVES.htm
Jan 07, 2011 | Intel (AXXSCD) Internal CD-ROM Drive
My computer can't see any IDE drives in setup i
i see do you use only 1 ide cable?if you only have 1 ide cable and it is connected to to of your drive...you must put one of your drive's jamper to slave....it must be the cd rom drive...hope it works...
Dec 09, 2010 | Dell OPTIPLEX GX60 Motherboard
How to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
Setting up gigabyte ga-686lx3 verion motherboard
Here's a link to where you can get the manual free and it will show you the jumper options and all. Hope this helps.
http://www.motherboards.org/mobot/manuals/Gigabyte/GA-686LX3/
Mar 29, 2009 | Gigabyte 440LX (GA-686LX3) Motherboard
Mobo only one ide connection socket for HDD & CD-Rom
yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will work....so............:))
If any problem just Ask me
Thanks
Iqbal
Apr 07, 2008 | Computers & Internet
KHCRW 52 24 52 CD-ReWriter not recognized
Change the Jumper To Master Or Slave.
CS Is cable Select, your computer may not support this Option.
If installing on a cable with a drive, already connected. i.e hard-disk. if the hard-disk is slave set the cd rom to master.
Enabling both channels, is the 2 individual slots on your motherboard. Primary And Secondary. Or IDE 1 And IDE 2.
This will solve your Problem.
Mike @ compurepair.
Feb 20, 2008 | KHypermedia (KHCRW522452) (20326452) CD-RW...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Mercury P4VM800M7 Motherboard Logo
125 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
