Question about Polaroid 1511-TLXB 15.4 in. LCD Television
Remote Control I cannot get my remote control to work with my TV. I've tried new batteries, I've even tried a universal remote, but I cannot get anything to work with my TV.
  • kbeacom Aug 26, 2008
    The TV is a Polaroid 1511-TLXB & the remote is a Universal RM24914 & I have basic cable thru Time Warner.
You have several options:
1) Call your cable company for assistance.
2) Call Polaroid for assistance (that's who helped me).
3) The remote codes are listed with the instructions in the manual for the remote. Follow the directions using the listed codes for Polaroid. If they don't work, try using the codes for Sharp & Goldstar. Some other codes given to me by Polaroid are 0178, 6714 and 0205 {0205 worked for me}. If your remote requires a 5 digit code, placing a "1" in front of the other code values may work, as related to me by Polaroid customer service.
In the end, there's the possibility that a problem exists with the TV itself.
Posted on Aug 26, 2008
  • 3 Answers
What remote & what TV? What cable STB?
Posted on Aug 23, 2008
SOURCE:
Technika X19/14E-GB-TCDU-UK with Grundig RC-7-1 universal remote
If code search using your Grundig universal remote control does not produce results, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Nov 18, 2017 | Televison & Video
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
My remote control will not work despite putting in new batteries. If Lkeft for a few hours it will work a couple of times before not working again.
Maybe time for a new remote. But first, try some different batteries and make sure there is clear path from the remote to the unit. If you have a universal remote, program it for the TV first and try it. If it works, your other remote should be replaced or use the Universal remote to control the TV.
Oct 12, 2010 | Sony KP-61HS30 TV
MY REMOTE WILL NOT WORK EVEN THOUGH I HAVE NEW
I HAVE SANSUI TV BUT ITS REMOTE IS NOT WORKING. SO GIVE THE SOLUTION.
Feb 22, 2010 | RCA Universal Remote Control
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
Component codes missing for universal remote
See if the remote has a learning function but you must have the original remote for this and new batteries installed..
Try these codes may help
004,009,027,029,030,076,106,127,130,165,182,183
249,251,255,278,308,309,310,313,316
363,
418,447,555,584
671,716,717,718.741,748,749,750,754,755,756
These are not just random numbers I,ve made up they have come out of a book I,ve got that explains how these codes are generated and these are the best match...Good luck and I hope they work for you..
Jan 02, 2008 | Philips PM435S Remote Control
No response from remote
Check whether the remote control is working properly or not by using remote checker. Even if it is the universal remote control you have to set the code for the particular model. Otherwise it will not work.
Sep 17, 2007 | Panasonic CT-32SF37 32" TV
Polaroid 1511-TLXB 15.4 in. LCD Television Logo
224 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
