Question about HP Office Equipment & Supplies
NEED to install printer again - HP Office Equipment & Supplies
I want a software of HP Deskjet D2360 to install my printer
Posted on Aug 18, 2008
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
Printer is offline
Hi Lacey,
Disconnect the printer completely and unplug from power.Reboot your PC.Check for any jammed papers in the printer paper paths,these may cause the printer to 'go offline.'
Connect everything again and make sure its well connected to your PC.
Turn the printer off and on again.Problem solved?
If not,uninstall the printer[hoping you have the installation disks],reboot your PC again and install the printer software again.
Hope this helps.Thanks Lacey!
Please rate this answer.
Nov 23, 2011 | Canon Pixma MX410 All-In-One Printer
Izaakzakei cant get my printer connected to my laptop i have downloaded the driver but its still not working
You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control panel...click on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then next...you computer should install the hardware for you printer.
After installed, restart again...to see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
Sep 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
After installing the software for my lan,I am getting "printer is offline"
If you are talking about installing the Lan card of the laptop ..and after that getting errors from the printer..I think that you installed it while the printer was hooked up ..and it seen the printer's card while doing ..and messed up with it ..
If the printer is on network ..just rest it to factory settings ..and make the settings again ..and after that run the driver in the laptop ..without the printer hooked up ..until it asks for it ..This will make it detectable again ..and run OK >.
another thing you can do is to run the printer and faxes wizard and locate the printer again ..but net before you turn it off..unplug from power and laptop ...rest it if you can ..and that plug it back to be recognized by the laptop again ..
If this will not cover your problem ..please explain in details what exactly you installed..in what conditions ..and what you need to do ..(how is the printer connected)
Feb 01, 2011 | Computers & Internet
I can't install the disc for the printer. It was done once before and worked, but now says I need to install again, but I can't
First you must uninstall the printer from the COntrol Panel->Add remove programs. Then reboot the PC. And then install it again with the printer disconnected. Once it is installed, then connect the printer and allow Windows to detect it and load its drivers. Then you are ready to use it.
Nov 21, 2009 | Office Equipment & Supplies
How do you scan a document?
install again with express if you not see any icon that mean u need install again printer plz remove your software
Oct 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I have had this printer for about 2 years or so. It used to work. Now it gets frozen on the USB printer port page when I try to print. So I went to the dell printer driver page and downloaded the printer...
no need new printer first uninstall old printer drivers from computer then check your printer model number and download exact driver again then install.
Jul 13, 2009 | Dell 725 InkJet Printer
PROBLEM ON INSTALLATION OF PRINTER
may i know if the printer is working right now or it does print??but it doesnt print you need to check if the printer icon is available in the PRINTERS folder in the control panel and if its available and says offline just try to click the icon the USE PRINTER ONLINE.if you doesnt have the icon you need to reinstall software used this link to download the software from hp website:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2510767&lc=en&cc=us&dlc=en&lang=en&cc=us
select you appropriate OPERATING SYSTEM..
send feedback for further troubleshooting
Sep 06, 2008 | HP Deskjet 2460 InkJet Printer
Unable to re-install printer/software
see this problem of printers not printing is to much try and do this disconnect the printer from the system then connect it again then try and instal it again.
Dec 11, 2007 | HP LaserJet CM1015 All-In-One Printer
42 people viewed this question
Seeker5211
Seeker5211
