Question about Dell Inspiron 1300 Notebook
Battery problem Hi man thanks for the posts fisrt of all I have the same problem with my battery I tworks when plugged in but wont charge the battery same sequence of lights flashing what do you mean by test it? What shoul I do to fix it thank you
  • dellchick Sep 10, 2008
    I too have this problem, but my battery does not have a test button or LEDs. my computer says its not installed and it is.
YAY! i found the solution to this - it fixed my SAME PROBLEM right away!
and for FREEEEEEEEEEEEEEE!!!!!!!!!!!!
http://worldtv.com/blog/guides_tutorials/fixing_an_overheating_inspiron_1300_laptop.php
there was a LOT of fluff in there, and now my battery is charging, my lap is not on fire and i am one happy camper.
Posted on Sep 10, 2008
  • 10 Answers
There is a button on the battery itself next to 5 LEDs. That is your test button. (mainly lets you know how much of a charge is left).
BTW, if this is an older battery (3 Years or more) it may need replacing due to a safety issue.
Posted on Aug 18, 2008
Sager 8880 wont run on ac adapter or charge battery, has new battery and ac adapter it does work with battery but now the battery is almost completely discharged and now i get battery light blinking and...
Hi Kenneth,
Have you checked to see if the charge connector on the laptop is loose when you plug the charger into it? You can see if it is by plugging it in and wiggle it around a bit. The charge light on the laptop might stop blinking if its moved and contact is made.
Thanks,
Gary
Aug 01, 2013 | Gateway MX6956 Notebook
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
My battery to my phone wont charge for some reason the chargers arent broken but it just wont charge help!!!!!
Hi the chances are the battery in the phone has bad cells this causes the battery to seem charged when its actually flat, the only option you have is to replace the battery and that will solve your problem.
when you get a new battery do the following.
every say 6 weeks let the battery go totally flat so that it wont even turn the phone on then do a full charge over night, doing this every six weeks keeps the battery at its best and prevents it from getting any bad cells so doing this will improve the life of the battery.
turning off bluetooth saves the battery as well if this is switched on all the time then this will drain the battery really quick its best you only turn it on as and when needed.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Sanyo SCP-2700 Cell Phone
The battery is low. turns over but wont start
Kill switch ok? (make sure it is on the run setting) Got gas? Check that the valve is on and you have gas.
Charge your battery. Check your plugs. (Got fire?)
Let me know what your results are - post a comment here. I want to help you with this problem
Thanks for posting your question at FixYa.com
Please vote
thanks
Dec 21, 2009 | 1992 Suzuki GSX 600 F (Katana)
Laptop Battery Wont Hold Charge
Hi there.
Chances are that one of the cells in the battery is faulty causing it to not charge up, if the laptop runs ok on AC power only then you have to replace the battery, try get a battery that you know works and try that.
Good luck and thanks for using FixYa!!
May 12, 2009 | Sony VAIO Notebook
Dell inspiron 1501
Hi there
Take the battery out and start the laptop up on AC power only, set the correct date, time and time zone, shut down the PC and remove the power jack, wait about 30 seconds then power it up on AC only again, If the date and time has changed the the cmos battery has run out and needs replacing. If it keeps date and time the problem is the battery or the powerboard controller that charges the battery is defective. If the battery is getting a charge, run the battery completely out of charge, then try to charge it again.
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Dell Inspiron 1501 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
PHONE WONT TURN ON, HELP!!!
Hi, did you try taking out the battery and letting it discharge overnight then pop the battery back in, plug the pda into the power mains and try to turn it on again?
Nov 28, 2007 | HP iPAQ hw6515 Pocket PC
Dell Inspiron 1300 Notebook Logo
195 people viewed this question
Alun Cox
