Question about GE Spacemaker JVM1640SJ Microwave Oven
Keypad buttons fail
Buttons on keypad have failed. Unit is two years old - second time I've replaced unit for same reason. Can I replace/repair keypad?
  • GE Master
  • 9,174 Answers
I always recommend that you use the hood / vent fan whenever cooking on the stove top. That can help keep steam out of the controls.
Also, I always recommend that users spray cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
I recommend a soft cloth since paper towels can scratch the plastic.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Posted on Aug 18, 2008
SOURCE:
LG Microwave LMHM2017ST some buttons on touchpad stopped working
touch pad needs replacing not sure if can replace look online might get lucky
Oct 24, 2017 | Microwave Ovens
Blinking electronic display on microwave
see the cause and proceed according. God bless you
but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 17, 2012 | Sharp Half Pint Microwave Oven
Whirlpool microwave/wall oven model # GMC275PDQ3 not working
see this steps and use the common sense NOT feared: unppluged the power cord:
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
God bless you
Jul 27, 2012 | Microwave Ovens
Buttons on LG microwave have stopped working
The keypad control board has probably failed, only option is replacement, but part alone is $97. or more, maybe cheaper to replace the unit.
Jun 23, 2012 | LG Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Worth fixing 9 yr old unit? Told the keypad going bad. Often powered off/on to reset is required. Expensive repair?Complicated? I am quite handy if part swap is an option. I recall hearing a microwave is...
Hi - I really do not like to condemn any machine however microwaves have become very inexpensive - more efficient - quieter and packed with more features than ever before for a reasonable price. If you are handy unplug the unit and remove the front panel (a few screws ) at the keypad to expose the keypad harness, please check the harness connection. It is not uncommon for a keypad to fail. If the keypad still fails I advise purchasing a new machine simply because the parts, shipping etc will likely exceed the pro rated value of your machine. I know it is hard to let go sometimes but in the case of old microwaves it is generally wise. Microwaves can last well over 10 years. The good news is you will be getting a warranty with your new one should you decide to go in that direction. Hope its the harness, Sincerely Brian
Nov 26, 2009 | GE JEM31 Microwave Oven
Emerson Problem
Your Control Panel has failed. Replacement of the Control Panel is your only repair option. Not cheap!
Feb 04, 2008 | Emerson MW8987B/W Microwave Oven
GE Spacemeker Microwave Oven xl1800
The Control Panel is failing. The Control Panel consists of a Keypad, and a Control PC (Printed Citcuit) Board. You can replace it as a complete unit. Not Cheap!!
Good Luck!
Feb 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Some of my Buttons don't work on my microwave
Chances are your keypad has failed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If yours is not found there, please reply back with your brand and model.
If you don;t prefer to repair it yourself we can help.
Jan 22, 2008 | Microwave Ovens
Keypad going out
The main reason door switches go out is by opening the door while it's cooking, instead of hitting the STOP button first. Otherwise, like anything man made, they can fail. And for safety's sake, they should all be replaced when one is bad. If a keypad is failing repeatedly, I would suspect outside contamination or an inherently bad design. But I've not before heard of repeated keypad replacement. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Hope this helps.
Nov 21, 2006 | KitchenAid KBMC140HSS Convection/Microwave...
GE Spacemaker JVM1640SJ Microwave Oven Logo
94 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
