Its not really a big deal. Could be just some ink that has leaked. All you got to do is wipe the rollers clean with a damp cloth and run off a few copies when the rollers are dry. You do not have to replace anything.
Hope that helps! Should you have any further questions,
please post them here.
If you are satisfied with my solution or have no further queries, please take a
moment to "Accept" this solution.
Thank you for using Fixya!
Cheers!
IrishDruid
Sir try to replace or put another ink cartridge on your device. before you put it be sure to clean the head. print another docs and see if still the same happening.
CHARCOIS
Should work straight out except perhaps the first few pages that would be printed would be a bit smudged too. Alternately, you can wipe the rollers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
You still try to use them but if they don't really work fine definitely they are already damage because of that, you may need to replace them so you can use the printer properly..
Hope that helps........
First try it and then see any problem is coming or not
Thanks. I'm pretty sure my yellow toner is defective. It had a bunch of gaps on roller. Tried wiping it but gaps came back. I ordered new toner but fear this will not be entire solution. Most prints have one centimeter of lightness on left margin. I don't think this is caused by the yellow flaw. Wondering if this could be developer. Or maybe fuser.
Spencer
