Question about Dell Inspiron 700M Notebook
2.0 USB port, items reading as 1.0
I have a 2.0 USB port, but every time I plug in any usb port in there, a notice pops up telling me I have a 1.0 and that it would be better if I upgraded to a 2.0!! HELP!!! Thanks
  • 10 Answers
Then your USB port or driver is actually 1.0. go to the dell website for you laptop and see what the latest updates are available.
Posted on Aug 18, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
I had just gotten my usb that i wanted to plug into so i can transfer some items from my Xbox360 to my computer but then i noticed that the last time i had taken out the wired controller it took part of a...
The USB port is likely broken for good. However, you can buy USB hubs like this one that take one USB port and splits it into four. They're also really cheap, that one being around $3.
Also, if you only need two USB ports, there is a third one in the back of your console, right above the network port.
Apr 16, 2011 | Microsoft Xbox 360 Console
I have 2 Lacie 2TB external drives. 1 of them does not appear anymore on my desktop it did the other day off and on. 1 or 2 times in the rebooting a disk formating pop up appeared saying it did not...
Try changing the USB port to connect it. Also try substituting the cable used to connect the errant disk. It may be a cable issue or a USB port on your computer.
Sep 08, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
I am getting a power surge in my usb port with my
This is usually the case if you have too many items plugged into USB ports.
If you have a USB hub plugged in then ensure it has its OWN power supply or try remove some items and your problems should go away.
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Mar 13, 2010 | Dell Latitude C610 Notebook
Error message keeps popping up about a usb error -- there are no items plugged into a usb port on the laptop! How do I stop this error message from popping up?
Try uninstalling the USB root hubs from the device manager and restart computer...this should resolve the issue. else try doing a BIOS update.
Mar 03, 2010 | Toshiba Satellite 5005-S504 Notebook
QDI kudoz 7 mauanl wanted
this time your got have a spammer, i tell you read the USB port at the motherboard then put the wire connection there
Jun 17, 2009 | QDI Group QDI KuDoz 7 Motherboard
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Windows does not start when I leave my printer plugged in
First if your USB cord is too long try to switch it out with a smaller cord. If that does not work please unplug printer boot up and enter the BIOS settings.
http://www.michaelstevenstech.com/bios_manufacturer.htm
Then check to make sure your boot sequence is setup to Hard Disk first and not USB, you need to make sure the USB Boot Device does not have priority over HDD.
Finally make sure that USB Emulation is not turned on in the BIOS.
If all of the above does not fix the issue you may have a faulty USB port or a bad mother board.
Jan 17, 2009 | Lexmark P4350 All-In-One InkJet Printer
Ultra traveldrive not readable
Try the HD on another computer and see if it runs if it does then is is the port, Check the USB port with another USB item like a camera or something, If the port works then it is the drive. USB drives can and do burn out from time to time.
rmatheson@wowway.com
Sep 27, 2008 | Computers & Internet
USB Power Surge Error
normally usb ports are plug/play it could be tht there is something wrong with your usb cable if i knew your mailing address i could send you a usb cable i have tons..
Sep 26, 2007 | Vivitar ViviCam 5385 Digital Camera
Dell Inspiron 700M Notebook Logo
49 people viewed this question
Alun Cox
