Question about RCA F27450 27" TV
My TV click on and off repeatedly when I try to turn it on...
I have a Sony Television and it started just clicking on and off when I try to turn it on. It never actually comes on now, just does this clicking thing and the picture stays on the screen for about 20 seconds. Is this something that can be fixed?
  • 129 Answers
Good day.
Try to check for loose contacts along the tv's circuitry. Also, check if you outlet is loose.
Regards,
chris
Posted on Aug 18, 2008
Volume is gone (except for a clicking noise)
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
Jan 22, 2013 | Sony KV-27V55 27" TV
The power/standby light blinks green 4 times, the tv clicks, then repeats flashing and clicking...no pwer
the problem on you tv is the fan is not working this is the big fan you see on the back of your unit , is very ease to replace take cover off and you would see the fan , when you look the tv from the back look at you left and there is , you may want to call sony that way you would get the right part , i have fix a lot of this tv with this problem
Jan 24, 2012 | Sony KDF-E42A10 42 in. LCD Television
I have a sony kdf-42we655 tv and when i plug it in i hear it click on. unfortunitly although it clicks on u cant see anything but black like its not on. I am not sure weather it is the ballast or lamp?...
unplug the TV's power cord. Press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
If this doesn't work, you should contact a repair shop or the place of purchase. Is the TV still under warranty or extended warranty?
Apr 13, 2011 | Sony KDF-42WE655 Television
TV WONT START UP - RED LIGHT COMES ON AND THERE IS A CLICKING NOISE AS IF IT IS TRYING TO RE START - IS IT THE LAMP UNIT OR STARTER?
if the lamp has gone the bottom light will flash if the top flashes there a problem with the tv there is reset you can do
  • Point the Sony remote control at the TV and press and hold the "Up" arrow button.
  • 3
    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
  • 4
    Select "OK" when shown the factor settings and the television has completed its TV reset
  • Read more: How to Completely Reset a Sony TV with a Blinking LED ' eHow.co.uk http://www.ehow.co.uk/how_6011902_completely-sony-tv-blinking-led.html#ixzz17Eijjdrn good luck regards shaun
    Dec 05, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
    My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
    TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
    Hope these info will help you.
    Thanks.
    Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
    I have a sony projection television. I was watching it and accidentally cut it off. When I went I turned it back on it is not powering back up. I am seeing the red light on the front blink a few times and...
    Hello.
    My name is Russ. Maybe I could help you, but I need to know model number of your TV (it is located on the sticker at the back of your TV next to serial number of the unit). Also I need to knoe exactly how many times red light is blinking. It does it repeatedly. Foe example: six blinks, pause, another six blinks and so on.
    Regards.
    Aug 11, 2010 | Sony Televison & Video
    Tv turns itself off and on.
    I just had this problem. The plastic back of the TV has a grated opening directly in the middle and towards the top of the TV. There is a fan directly behind. The grated opening was full of dust so air couldn't pass easily. I simply vacuumed the dust. I went the extra step and removed the whole back of the TV and vacuumed the entire space.
    I assume the internal temperature exceeded its maximum so the TV turned it self off. Cooled enough to try a restart, heated up, ...
    Oct 02, 2008 | Sony WEGA KZ-32TS1 32 in. Television
    TV won't turn on
    Hello Bob61E,
    life safty should be 1st priorty before opening of TV set ;)
    if you are skilled or qualifeid, then go-ahead and
    if its Sony TV, you will see stand-by light blinking while tv try to power up. let me know how many time this light blinks.
    May 27, 2008 | Sony KV-32FS12 32" TV
    TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
    When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
    Dan
    May 12, 2008 | Televison & Video
    Sony FWD50PX2/S 50 in. Plasma Television power problem
    It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
    Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
    RCA F27450 27" TV Logo
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
