Question about Sony Playstation 3 (PS3) Console
Internet Connection Well the guy with the router says its wireless with the antenna, but still when i go to custom under network settings, it does not ask me wired or wireless. and when i view my internet settings it all says wired. if it doesnt come up how can i change the wired to wireless
    Sergeant:
    Champion:
  • 236 Answers
Then you have to update the ps3's firmware.
Use a computer and go here and click the bar that says "download now".
when you are done downloading, save the file on a flash drive (also called thumb/USB drive), compact flash, SD card or memory stick. it must be at least have 140MB free space.
On the storage, copy the file you downloaded in the \PS3\Update folder.
Insert the media in the ps3 via usb or card reader.
On the Ps3, under "Settings", go to "System Update".
select "Update via storage media".
click ok to start the upate. Follow the directions.
After its done, now try to change your network settings.
Posted on Aug 18, 2008
The Internet LED is red when there is no Internet connection
Unplug router for a minute or so and re connect also check if the computer is even recognizing the router in control panel under network conections
Jul 09, 2012 | NETGEAR CONSUMER Netgear Dgn2200m Wireless...
Tip
Connect PS3 to the Internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Back to top
Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust the network settings. These settings may change depending on the type of access point and the network environment you are in.
The following instructions apply most of the network configurations.
  4. Select "Wireless", press the x_button.jpg button.
  5. Select "Scan", press the x_button.jpg button.
    The system will search for access points within range and display them as a list.
  6. Select the access point that you want to use, press the x_button.jpg button. (An SSID is a code or a name that is assigned to the access point. If you have no clue which SSID to use or if the SSID is not displayed, contact the person who set up or maintains the access point.)
  7. Confirm the SSID for the access point, press the right button.
  8. Select the security settings as necessary, press the right button.
  9. Enter the encryption key, press the right button. (The encryption key field will display an asterisk (*) for each character you enter. If you do not know the key, contact the person who set up or maintains the access point).
  10. Select Easy or Custom and adjust the settings.
on Feb 20, 2010 | Video Game Consoles & Games
Loosing internet connection every 15 minutes
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router
Feb 18, 2011 | Linksys WRT120N Router
How to secure the router
HI
please find the ans.
Features
  • Firewall protection for your network
  • Parental control to supervise Internet activity
  • Works with wireless 802.11b/g adapters
  • Backward compatible with 802.11g and 802.11b devices including game consoles and digital media player
  • Secure wireless network using advanced
  • WEP, WPA, or WPA2 encryption
  • Easy to get started with D-Link Quick Router Setup Utility
Description The D-Link DIR-615 Wireless N Router provides better wireless signals for your network than existing wireless 802.11g technology. Upgrading your home to Wireless N provides an excellent solution for sharing an Internet connection and files such as video, music, photos, and documents. D-Link Wireless N products use Intelligent Antenna technology to transmit multiple streams of data which enable you to receive wireless signals in the farthest corners of your home. Not only does D-Link's Wireless N technology extend your wireless range, it also works with your existing 802.11g and 802.11b wireless devices.
Easy To Set Up:
The D-Link Quick Router Setup utility quickly configures your new Wireless N Router to get you up and running in minutes. Our D-Link Quick Router Setup walks you step by step through the installation process to configure your Internet connection, wireless network settings and security, and everything else you need to get your network up and running so that you don't have to be a networking expert to get it set up.
Easy To Secure:
The DIR-615 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Supportfor WEP, WPA and WPA2 standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this Wireless N Router utilizes dual active firewalls (SPI and NAT) to prevent potential attacks fromacross the Internet. Delivering great wireless performance, network security and coverage, the D-Link DIR-615 Wireless N Router is ideal for upgrading your existing wireless home network.
Specifications Technical Specifications Standards: IEEE 802.11n (draft) IEEE 802.11g IEEE 802.11b IEEE 802.3 IEEE 802.3u Device Interfaces: 4 10/100 LAN Ports 1 10/100 WAN Port Antennas: Dual external 2dBi Gain reverse SMA antennas Security: 64/128-bit Wired Equivalent Privacy (WEP) data encryption Wi-Fi Protected Access (WPA, WPA2) Advanced Firewall Features: Network Address Translation (NAT) Stateful Packet Inspection (SPI) VPN Pass-through / Multi-sessions PPTP /L2TP / IPSec Device Management: Internet Explorer v6 or late Mozilla Firefox v1.5 or later Java enabled browsers Leds: Power Status WAN WLAN (Wireless Connection) LAN (10/100) Internet Status Power Input: DC 5V 2.5A, through external power adapter Dimensions: 193 x 116.8 x 30.5 mm Weight: 940 grams (0.7 lb) Operating Temperature: 0ºC to 40º C Storage Temperature: -20ºC to 65º C Operating Humidity: 10% to 90% Storage Humidity: 5% to 95% Certifications: FCC Class B IC CE
Dec 11, 2010 | D-Link DIR-615 Wireless Router
Can not connect to internet Do I need to connect directly to the modem. i have wireless Interent in my home but th emodem is 3 rooms away. Should I get a second modem?
here try this and remember to leave a testimonial.
Wired Connectivity:
  • A cable modem
  • Ethernet cable. (Available with the PS32_bing.gif)
  • When you have a wired connection to the Internet2_bing.gif, it is not necessaryto adjust any of the default settings. (It is done automatically). Ifyou aren't able to connect with the default settings, follow theinstructions to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  1. Select "Internet Connection Settings", press the x_button.jpg button.
  2. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  3. Select "Wired Connection", press the x_button.jpg button.
  4. Select Easy or Custom and adjust the settings.
    • Wireless Connectivity:
When you try to connect wirelessly to the Internet, First adjust thenetwork settings. These settings may change depending on the type ofaccess point and the network environment you are in.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
I cant connect to the internet
Playstation 3: How to setup your Internet connection This article helps you in setting up the Internet connection for Playstation 3 To enjoy the online capability of Playstation 3, you need to connect it to the internet. You can do it in two ways:
  1. Wired Connectivity.
  2. Wireless Connectivity.
Wired Connectivity:
  • A cable modem
Back to top
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your provider
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
Can u please help me connect my ps3 to play games online i have usb modem connected to laptop, with ethernet cable connected to ps3 from laptop......... i live in australia
Wired Connectivity:
  • A cable modem
Back to top
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
My wireless adapter does not detect any reception from the router. i have another laptop at home that could easily detect reception from the router. what should i do?
since the laptop is connecting to the router and is having the internet access as well then clearly the problem is with the adapter or with the pc using the adapter.
Following steps can be considered :-
1)If the PC is using OS as windows XP then , click on start menu and then go to control panel and then open network connections from there.
2)Under network connections an option for wireless connection exist , right click on that option and then click on properties.
3)Under wireless network connection properties there are three tabs general , wireless network and advanced.
4)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom.
5)Then , Right click again on wireless network connection and then left click on view available wireless network.
6)List of available networks will be there , select the network you use and try connecting to it , if it gets connected then the internet access will be there.
Nov 15, 2009 | HP 290563-B21 Network Adapter
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
NOTE:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
My wireless internet connection is getting interrupted every few minutes
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
  2. Wireless settings of the router are still set to default.
  • Manufacturers suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Having default wireless settings on the router may cause conflict with other Linksys routers within your network range. Manufacturers suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
Thanks, Joe
Jan 11, 2009 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
