Question about GE 25952 Cordless Phone
25802GE3-A Phone -Needs Registration
Don't have manual. Have moved & now all 4 phones need registration. Tried but attempts at registration "Failed".
Help, please.
Remove the batteries from the handsets and wait 30 seconds and then place them back in. It will allow you to register them again.
Posted on Aug 18, 2008
  • thorbin661
    thorbin661 Feb 02, 2013
    This does not work. I even took fully charged batteries from a handset that works (and put the batteries into the handset that would not register) and even after going throught the steps to register the handset to the base, it would not complete the registration (the base could not locate the handset).
How do I register my vtech phone?
"Register" refers to the pairing of the handset to
the base so they can communicate securely
in private via an encryption scheme so no one
can easily evesdrop.
When you first set the phone up for use, you will
need to effect the registration then:
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jan 03, 2015 | Vtech CS6829-26 2 Handset Answering System...
Fring registration attempts exceeded plz help me
I have axceeded problem samsung galaxy mini 2 please help me
Mar 21, 2013 | fringland fring Group Video Calls Chat
SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
May 08, 2009 | Nokia N70 Cellular Phone
I get an opening message: "SIM card registration failed" - what does this mean? then i can't receive nor send any msgs.
1, The sim card is turned off, if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
May 08, 2009 | Nokia 6300 Cellular Phone
Tried to reregistering
Hi
Please try the following procedure:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 27, 2009 | Uniden Cordless Phone
Sim card registration
No, your handset seems ok. Its related with your SIM card's registration. Have you tried it on some other phone? Try putting the SIM card on another phone. Most probably the validity of your SIM card has expired. Please check with your service provider for re-activation if that is possible. Please let us know how did it go...
Feb 07, 2009 | Nokia 3110 Cellular Phone
Dect 6.0
Hi :I have the same problem and the dealer couldn't help me .I replaced the battery but that wasn't the solution.Glad to see i'm not the only one with this problem
Mar 22, 2008 | Uniden Cordless Phone
Cordless GE phone issue. 25825GE3-A
1. press the "talk" button FIRST
2. then press "program" button and follow instructions on screen
only one phone said "needs registration" but had to register all 4 phones but this worked for me
hope this helps
Sep 11, 2007 | Uniden Cordless Phone
GE 25952 Cordless Phone Logo
1,385 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
