Question about Frigidaire Refrigerators
I cant get my fridge settings right it is either freezing everything or starts leaking
    Genius:
  • 1,198 Answers
The first thing to do is a complete defrost. This requires emptying the freezer, fridge, doors open, plug out. The freezer should drain to a tray in the dusty area under the fridge. Vacuum the coils while you're there.. If it doesn't drain to there, you have a stuck drain. If it's just ice, it'll melt sooner or later. It could be a pea or something stuck in there. You have to remove the freezer inside cover to find out, a lot of trouble. If you do, check the defrost coil, they break easy. Sometimes the defrost timer breaks. If you can find it, it should turn the compressor off and the defrost coil on once a day. The fan and lite will still work.
Posted on Aug 18, 2008
SOURCE:
My samsung fridge is freezing everything rock solid. I hear it may be a damper problem but i cant figure out how to get to the damper
check the thermostat setting for the fridge
it should be around the 4-5 mark as 1 or 0 is freezing
Jun 28, 2018 | Samsung Refrigerators
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
Oct 23, 2017 | Refrigerators
Fridge is freezing everything and staying on 3 degrees
Hi, the thermostat is faulty replace it. There is nothing else that can make a fridge exceed the set temperature but the thermostat.
Sep 10, 2014 | Refrigerators
I don't know what happened to my refrigerator but it is starting to freeze everything. I couldn't change filter because it was stuck, frozen in place. So i had to turn the fridge off so it could thaw out...
1 setting on a fridge is as cold as it can get so it will be close to freezing
should be set on 4 or 5
next if it still is freezing then the thermostat is failed and you will need to replace it
May 09, 2017 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Our hotpoint fridge freezer ffm74 has stoped working. The freezer doesnt work and the fridge is freezing everything.
hi the fridge requires cold air from the freezer,the air cant get in there due to ice blockage,defrost appliance for min 36hrs and then once the appliance reaches approx -12o the fridge should start to go cold
Aug 03, 2009 | Refrigerators
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Refrigerators Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
