Question about Samsung YP-K3 MP3 Player
Will not turn on
It will not turn and when it does it comes in blurry and i have all ready tride the reset button but did not work???????????????????????PLEASE HELP!!!!!!!!!!!!!!!!
  • J-Rod10 Aug 18, 2008
    i have not fixed it yet but know it is making a buzzing noise
  • snl0923 Aug 27, 2008
    when i took it off the charger one day it would not turn on and has not since than
F*****g d**n s**t! this thing doesn't wOrk
Posted on Aug 21, 2008
SOURCE:
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
Panasonic dmr es10eb ebl
have you tride unpluging .if so is there a factry rest in the menu if so do a factry reset
Sep 30, 2013 | Televison & Video
The picture started to get blurry, after being turned on for 10 minutes would clear up, now just stays blurry and almost no picture at all.
Hi
Thanks for using FixYa. To reset the picture you’ll need to reset all the Video menu options to their original factory setting for which you’ll need to follow this step-by-step procedure---
Press the Menu button and then use up or down arrow button to select the Video menu. Now press the right arrow button and then use up or down arrow button to select Video Reset then press the right arrow button to reset the Video menu options to original values.
If still the problem persists, then you’ll need to check for local interference such as an electrical appliance or power tool and also check the antenna. If required change the direction of the antenna.
To resolve the issue of Blurry Screen, first check whether all the cables from your dish network are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. So we are doing real small adjustments. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run about 300-500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 18, 2009 | Televison & Video
Thunderstom et off my alarm...
disconnected siren from main sorce, by unscrewing the correct wire from the box... then turned on breaker....
Sep 20, 2009 | X-10 25x25x10 - 5VDC
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
May 03, 2009 | Olympus SP-560 UZ Digital Camera
Blurry images on camera
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
Resetting lamp hour meter
It is the MUTE button on the remote and the VOLUME DOWN on the TV.
May 11, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Lens error with a slight twist
See my posts on this problem.. This may be that the lens is off track. You can try to force it in and out as you turn it on and off. You can damage the camera, but if you know that it is already damaged, may be worth a try.
Apr 25, 2008 | Nikon COOLPIX L3 Digital Camera
Screen picture is very blurry
you may have higt voltage block goin bad this a job for experienced technician becouse replacing the hv block you may brake one of the picture tubes
Mar 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blurry images
Still fairly you - try the makers support site a repair or replacement may not break the bank
Aug 16, 2007 | Fuji FinePix F10 Digital Camera
Samsung YP-K3 MP3 Player Logo
23 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
