Question about Coffee Makers & Espresso Machines
DURABRAND COFFEE MAKER MODEL CM 4112D
OK U WILL NOT BELAVE IT I BUY DURABRAND COFFEE MAKER MODEL CM 4113D OFFCURSE THE ELCRICETY IS 120 VOLT IT DOS NOT WORK AT ALL AND IT IS BRAND NEW , I NEED YOUR HELP TO FIX IT AND ALSO I NEED THE BOOK FOR THAT COFFEE MAKER,ALSO THE TOP COVER FOR THE WATER TANK OF THE COFFEE MAKER TOO
SOURCE: durabrand (model # cm4113d) coffee maker
Use Coke, put 200ml in water tank and leave overnight, then empty and rinse with tap water
Posted on Jun 09, 2008
  • 74 Answers
SOURCE: No coffee
Does it come out water from the steamer?
if that is the case I would clean the filter on the machine.
Posted on Jul 16, 2008
SOURCE: operating instructions
Go to www.Gevalia.com customer support. They have the manuals there.
Posted on Aug 21, 2008
SOURCE: coffee maker parts
need a heating element replacement for model cm 500 coffee maker. How much does it cost? Mark
email to mmtazzy @yahoo.com
Posted on Sep 23, 2008
SOURCE: Need Replacement pot for black Kit. Select. Dual Pot Coffee Maker CM-202
Select Brands
Kitchen Selectives
Select Brands
Customer Service Or Call 913-663-4500
To order replacement carafes for the CM-202 Dual Coffee Maker you have to call Customer Service at 913-663-4500 - This item cannot be ordered on line.
Posted on Jan 01, 2009
I was cleaning the coffee maker. The next day the lights wouldn't turn on, so I think water got inside it. But now it's working. Is it ok to plug it in unattended or could it short?
Dry it well. Then it *should* be fine.
You might put the cm with a desiccant, like microwaved rice or those little moisture boxes that come in pill bottles. Leave it for a day or so to soak up any remaining moisture.
The lights/controls of the cm actually run at a low wattage; a malfunction there should not be dangerous unless something causes the heating elements to come on. They are built to be okay if they're on with no water/dry pot, so as long as the cm is away from anything flammable--standard procedure for a cm anyway--it shod be fine even if it turns itself on.
Another option, and the one I recommend, is to go buy a new cm. You should not have to worry about the antics of your small appliances. A new cm will be cheap--and safe--and would set your mind at ease.
Mar 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Where i can bye one in france
The pots we use , uses 120 volts in France they use 220 volts. So you would need a converter kit they sell a the airport. Good luck. Ron. PS some hotels have 120 volts.. Call first.
Dec 22, 2012 | Faberware FCP280 Coffee Maker
I'm looking for the coffee pot only for kitchen selectives cm-312-p, where could I buy one?
Select Brands, the maker of Kitchen Selectives, doesn't list your model. This might mean it's no longer in production or was a custom model for a retail outlet. This page at their site gives contact information. All I can suggest is that you contact them and see if they can tell you where you can find an original replacement, or see if one of the universal replacement carafes at retail stores might be a close enough. Good luck, and thanks for using Fixya!
Dec 15, 2010 | Kitchen Selectives CM-202 Coffee Maker
I brought the coffee maker to Brazil and here is 220 VAC isntead of 120VAC . Do you think it will work with that thing, sorry dont know the name to change the energy???
Its called a converter? Drops the 220 to 120 maybe? As long as the end result is operation on 120VAC you will be ok, otherwise you will be shopping for a new coffee pot.
Eric
Jun 20, 2009 | Mr. Coffee ADX23 / ADX20 Coffee Maker
No lights and no display. I have verified electrical outlet is providing electricity to the unit.
Upon visual inspection of the PC board, a small portion of the board had been burned. Using a voltmeter to check components in that area, it was discovered a 24 volt zener diode was nonfunctional. I then purchased two 12 volt zener diodes (no 24 volt was available), and installed / soldered them, in series, on the PC board. I then reassembled the Gevalia cm 500 unit and made delicious coffee. What remains unknown is what precipitated the failure of the 24 volt zener diode.
May 23, 2009 | Black & Decker GT300 Coffee Maker
Select Brands
Kitchen Selectives
Select Brands
Sep 10, 2008 | Kitchen Selectives Coffee Makers &...
Coffee maker parts
Sep 01, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
114 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
