Split Heat Pumps - Cheaper than Air Conditioners?
Hey, I am looking for a way to save on electric costs during the mild winters here on the Aegean coast of Turkey, my apartment does not have any built in heating system, ducts, etc., it is 140 square meters, the humidity outside is maybe 50-60% during the winters I am guessing, The temp gets down to O Celcius on occasion, but mostly stays at 2-4C or higher. Does a split heat pump make sense for me? I am presently using an Airwell A/C and the electricity costs are whew! Spot heaters are not satisfactory to my wife and I have an infra red heater, not really what I am looking for. I am thinking that some kind of mixed split heater/cooler might be ok, but I am not too sure how it differs from my A/C. What is the difference? What is the energy saving for a more green technology? Are there other heating sources that I am overlooking? I want to save costs, I want to look at any alternative.
Thanks a lot!
Take care,
Darryl
  • dazzer64 Aug 18, 2008
    This device ad you sent me is nice, but doesn't answer my question really!
    Yes, I have used gas before and I still do, but find that the heater can't be left on safely at night and there are problems getting an even heat. The A/C provides a more comfortable environment overall, except for the cost of electricity. Is there any expert on this site that deals with heating systems? Heat pumps that take heat out of the air are quite cost efficient I have learned, but I need someone that has done the math on cost recovery. Getting someone to answer emails or give a direct answer without getting paid is really hard these days! Hence my putting the question to this forum.
    Genius:
  • 2,035 Answers
IF your for ways to cut the electricity bills and be part in reducing global warming .You need to install solar AC :
Please click on this link:
http://www.solarpanelsplus.com/
Good luck..
Posted on Aug 18, 2008
  • 157 Answers
Have you considered using gas heating. Gas heating is cheaper compared to using electricity and is more greener (environmental friendly) since it saves on using electricity ( electric plants use coal which is harmful for the environment). Personally Ive used gas heating and surprisingly is very good especially if u have a reasonably small apartment like yours
Hope this helps
Cheers
    Brigadier General:
  • 3,614 Answers
SOURCE:
Why does aux heat come on when not set for aux heat
The "Aux Heat" setting on many heat pumps is electric heat. The electric heat will turn on when the outdoor temperature is too low to extract heat from the air. This can cause a significant increase in your electric bill if it remains too cold for the heat pump to work as designed. This is why heat pumps are used more in moderate climates as opposed to those that experience much colder temperatures. The electric heat also turns on during the "defrost cycle". Both of these conditions are normal. The video below may help you understand a little better.
Dec 08, 2015 | Heating & Cooling
Multi split no heat wanted in bedroom in winter?
Keep the temp in required setting. That's enough to save your A/c.
Sep 20, 2014 | Heating & Cooling
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Jul 03, 2008 | Ruud UBHC Air Conditioner
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
