Try right-clicking your desktop and selecting "properties." On the
window that comes up, select the "desktop" tab, then click "customize
desktop." On the next window, select "recycle bin (full)" and click
"restore default," then repeat with "recycle bin (empty)."
If
that doesn't work, when using Tweak UI, just left-click "desktop" (NOT
the plus sign next to it) and you'll be presented with a list of
possible desktop options. Just make sure that Recycle Bin is checked.
You can also click "repair" in Tweak UI, then select "rebuild icons"
from the drop-down menu and click "repair now."
To fix this issue in Windows Vista, follow these steps:
Next stepsCheck whether the problem
is fixed. If the problem is fixed, you are finished with this article.
If the problem is not fixed, you can try the procedure in the
"Workaround" section.
Back to the top
To fix this issue in Windows XP, use one of the following methods:
Method 1: Use the program that removed the Recycle Bin to restore the Recycle Bin
Note If you used the TweakUI program to hide the Recycle Bin, follow
these steps to restore the Recycle Bin to the desktop. If you did not use the TweakUI program, see Method 2 or Method 3.
Important
This section, method, or task contains steps that tell you how to
modify the registry. However, serious problems might occur if you modify
the registry incorrectly. Therefore, make sure that you follow these
steps carefully. For added protection, back up the registry before you
modify it. Then, you can restore the registry if a problem occurs. For
more information about how to back up and restore the registry, click
the following article number to view the article in the Microsoft
Knowledge Base:
322756
How to back up and restore the registry in Windows
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are using the classic Windows XP Start menu
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Open Personalization by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
In the left pane, click Change desktop icons, and then do one of the following:
To remove the Recycle Bin from the desktop, clear the Recycle Bin check box.
To display the Recycle Bin on the desktop, select the Recycle Bin check box.
Click OK.
for witch OS XP VISTA 7 each has a differnet way
