Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Aug 18, 2008
When login it says done and the screen is blank, it wont allow me to get in
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16
Points
Wont allow two computers on atr same time
have you performed a Linksys reset:
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
Router setup
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
tip
Try blank. here is the methods I know. The first thing which you check if...
If you have only one Admin account in Vista and have forgotten the password for the same and dont want to reinstall the operating system and land up loosing all your data, this tip is for you.
1) Restart the PC with the Vista Boot Disc.
2) Select Repair Your Computer option
3) Select the Command Prompt
Or - If you dont have a Vista Boot Disc then boot your PC to DOS using any Dos boot disk or other O/s disc.
4) goto "C:\"
5) Navigate to C:\Windows\System32 ( cd c:\windows\system32)
6) Now we will rename the utility manager to cmd.
Type the following commands,
- ren cmd.exe cmdold.exe
- ren utilman.exe cmd.exe
exit
7) we have renamed it successfully.
8) Restart the PC without the disc, reach the screen where you are asked for you password.
9) You will see a white blue icon on bottom left.
10) Click on the icon and CMD will open up, type the following command in CMD.
- net user administrator /active
exit
11) Restart the PC, and you will find you have one more administrator account
12) logon with the new account, goto user accounts and remove the password for your old account.
13) restart the PC with the Disc again, and goto the command prompt as we did in the step 1-3.
14) type the following command,
- cd c:\windows\system32
- ren cmd.exe utilman.exe
- ren cmdold.exe cmd.exe
15) restart the PC, and logon to your own account, open CMD by going from start menu.
16) type the following and restart the PC.
- net user administrator /active:no
17) restart the PC and now you only have one account and thats your own account.
on Dec 11, 2009 • Computers & Internet
2answers
Forgot password
1. Start up into safe mode (press F8 at startup) 2. log in as 'administrator' 3. go into control panels, users, and clear the password on the account that you have a problem. 4. restart.
1helpful
I try loging on to my windows but the log on screen dont allow me enough space to put in the letters to my password how can this be fixed
If you Windows is XP, try this, when you reach the logon screen, move the mouse cursor on the blank screen and click once, now press Ctrl+Alt+Delete twice on the keyboard, type in your username and try with the password. If still it doesn't allow, then type in "Administrator" on the username box and press enter, leaving the password blank. Most systems has no admin password, so if it's same with your's you'll be able to do that and you'll be allowed to login a the administrator. Once you are logged in, go to control panel and change the password of your user with a shorter one. You can now log-off from the administrator's account and login to your account with the newly created password.
Good luck.
Thanks for using FixYa.
My key pad will only allow me to type in my password other than that i cannot type anything any ideas????/
Infected by virus. After login blank screen.
Try ctrl alt del after login and choose task mnager.
If you can do it mean the solution is FORMAT@RECOVERY
1helpful
2answers
I turn on the laptop and it gets to the login screen. When I login the screen blacks out.
There seems to be an issue with your Operating System. Please try the following :
  1. Boot the computer in Safe mode
  2. Do a system restore
  3. Restart in normal mode
If this does not work you might need to repair your Operating System.
10helpful
4answers
I lost my Computer's administrator password, is there any solution without reinstalling windows?
Hi, manav.
Yes, there is a way to access your locked computer without re-installing OS. Try using this password recovery software tool as it helps to reset your lost Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Should help you get rid of your problem. Regards.
61helpful
17answers
Forgot asus laptop password Windows vista
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
2helpful
Window will not reboot after
try leave the password blank.
you know? When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So try to logon as adminstrator ,here is the guide:
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
if that doesn't work,then just learn from others how to reset windows password with Windows Password Recovery Tool.
2answers
I HAVE FORGOTTEN THE PASS WORD ON THE DESK TOP ACER COMPUTER
which password ru forget os password or bious password
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
