Question about IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop
Installing modem on a new install of windows, I cannot get the modem to work. There is a yellow mark next to "PCI communication device". I have the drivers for the modem but XP will not find it. It is a IBM Netvista machine with a 6043KAA motherboard and I cannot find any information on the IBM website. Any ideas?? mukiduk@gmail.com
  • allanw Aug 23, 2008
    I have since successfully installed it. I found out that XP installs its own modems that do not work with a PCI modem and I had to make sure they were all deleted before trying to install off the manufacturers disc. (Dynalink)
    How I stop XP from loading drivers when I first turn the computer on with the modem installed, I do not know.
    Problem Solver:
  • 44 Answers
By the looks of your question, it appears you may have an internal PCI modem. If that is the case, please state your PCI modem brand and model. You may have what is called a WinModem or "softmodem" because they were usually US Robotics modems made strictly for windows. They are known to be buggy with their software drivers and hard to install but not impossible. Since softmodems use your CPU's power one solution would be to change to an external modem (since they have their own processor) and save yourself some headaches later on.
Thanks.
Posted on Aug 18, 2008
Re: Reinstalling Windows XP - Finding new drivers
Pick latest and up to date drivers for PCI Modem, Video Controler etc at that HP web page and installed them.
Oct 27, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
PCI Slot 5 (PCI bus 1, device 7, function 0) IN DEVICE MANAGER THERE IS A YELLOW QUESTION MARK NEXT TO PCI MODEM.EVERYTHING SEEM TO BE WORKING NORMALLY BUT WHEN I START MY COMPUTER I AM BEING INFORMED...
If you don't need the modem, you can safely disable this questionmarked device in Device Manager, so it does not nag you every time you start Windows.
As far as the disk is concerned, you may try going to Disk Management (in XP you right click My Computer and choose Manage, a Computer Management window will show Disk Manager will be on the list near the end).
Study the list of volumes listed in Disk Manager; if you see a volume of more-or-less the same capacity as your ext. disk, and without a drive letter assigned, than right-click that volume and choose Assign / Change Drive Letter. Choose a letter farther into the alphabet so it doesn't interfere with any existing volumes - my favorite is X: for eXternal :) - and confirm.
After that operation the drive should appear in My Computer.
Jul 24, 2011 | Computers & Internet
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
GeForce6100SM-M lan problem
Hi dadynidhen, there is another way to install the LAN driver & that is through windows system properties. Find the yellow question mark again & follow the instructions below.
Right click once on the yellow question mark, a window will open & Left click once on “update driver”. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Left click on the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find the folder in your system that holds the 32bit LAN driver. High-light the 32bit folder by left clicking on it once. Than click OK.
Windows will see the driver files & install the driver. Once done restart the system. Run windows update service. There may be an update for the LAN driver.
Mike
Apr 11, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Pci modem
try to do a microsoft update if you have access to the internet, this will download any hardware drivers that it finds and installs it for you.
hope this helps
regards
Nov 20, 2008 | Computers & Internet
After installing cd and following directions to install my Linksys wpm300n wireless-n pci adaptor the directions say to power down pc,installcard hookup antenna and re power up pc.but i get no futher set...
Click on Start - right-click on my computer - click on properties - click on hardware - click Device Manager
Look for your wireless adaptor in the list. Probably under Network adaptors. If it is on the list and there are no yellow question marks or Exclamation points next to it then you have successfully installed the device.
If there is an item that says unknown communication device with a yellow question mark next to it (?), put the set up disk back in and reinstall.
Most of the time when you install a new device in a pci slot, you must install the device physically in the computer first before running setup.
May 03, 2008 | Computers & Internet
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop Logo
87 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
