It's the Flapper or Flush Valve.
Get some green or red food coloring and a flashlight. First remove the tank lid and lift the seat and cover up against the tank. Take your flashlight and shine it on the back of the bowl, where the water line is. if you can see water coming down the back side of the bowl and
disturbing the calm water ie. making ripples. ( be patient and watch carfully). If you can see the water being disturbed most likely its the
Flapper.
Now take your flashlight and point it down into the
flush valve fill tube.
That's the thing that looks like a pipe standing up in the center of the toilet tank coming out of the water about an inch or so. Look for water very slowly pouring into this tube from the inner walls.
look from the top all the way to the bottom of the tube. If you see water leaking into the tube you need to replace your "Flush Valve".
That's another post...
If not, then most likely it's the "Flapper" put the seat back down and sit on it facing the tank.
Reach into the tank and lift the flapper up and feel with your fingertip the flapper seat by circling the seat. Like you would a glass rim to make a tone with it. If you feel a nick anywhere on the seat you will need to repair the flush valve flapper seat. If not then you need a replacement flapper. If you cant see/find any of the leak problems as mentioned above then it's time to use the food coloring. Add it to the water in the tank.
DO NOT FLUSH ! Let the dye mix with the water and then start to inspect the areas as mentioned above. ( Back of bowl/water line and the fill tube in center of tank). Use the flashlight to find the colored water in the areas as mentioned.
Before making any repairs turn the water off to the toilet.
PARTS:
FLUSH VALVE REPLACEMENT
If you need to replace the flapper seat flush
valve. Because you found a nick in the seat rim, FLUID MASTER makes a great
repair kit for that. Follow
their instructions. Hint: Make sure the
existing seat is dry before installing the
fluidmaster repair kit. Also you get one shot at it. The adhesive is strong you wont be able to pull it back off once you install it.
FLAPPER REPLACEMENT
Take your old one with you to Lowes/Home Depot and match it up.
Hint: Once you put the flapper on, take out most of the slack in the flapper chain when you connect it to the flush handle. once you're happy with testing the dry flush cut the remainder of the chain off with **** ( wire cutters).
If the problem is a cracked overflow tube you'll need to replace the flushvalve assembly. If so you may email me at
[email protected] and we'll go over that prosess on the phone if you'd like.
I hope this helps.
Good luck,
Mike.
ps. Don't forget to click on the hyperlink above for a cut away view of the toilet tank.
