Question about Royal VF1012mx Shredder
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
    Genius:
  • 1,218 Answers
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Posted on Jul 20, 2011
  • Jody Isselbacher
    Jody Isselbacher Aug 27, 2016
    So how to you fix "dirty eyes"?
SOURCE:
WON'T STOP SHREDDING WHEN ON AUTO
You will probably find some shredded paper is blocking the sensor in the middle of the paper feed slot
Feb 26, 2013 | Black & Decker BD10P Shredder
I've lost the manual what is the maintenance on the VF 1700mx
Shredders need no "real" maintenance......if you can open the top cover once per year and clean out any debris that might build up inside...other than that just occassionaly put some shredder oil onto a sheet of the paper you are shredding to help in lubrication/cleaning of the cutting teeth of any builld-up of dust and debris that take place during the shredding process.
Jul 18, 2011 | Royal VF1700MX Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Royal VF1012mx Shredder Runs and will not shutoff
Try using compressed air to blow off the sensors , as they may have paper dust on them, I f that doesn't work try Alcohol and a Q tip to clean the sensors, as alcohol leaves no residue.
Please be sure to unplug the machine before attempting any repairs.
Apr 18, 2009 | Office Equipment & Supplies
Shredder won't grab paper
there has to be something in the path.
once you put the paper in it triggers a sensor that rotates the blades and grabs the paper there is nothing else in between the entrance and the blades. get a flash light and lok in to see what is blocking the path.
unless there are some paper in between the teeth /blades, that need to be cleaned out.
Sep 05, 2008 | Fellowes PS60C-2 Shredder
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Royal VF1012mx Shredder Logo
901 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
