Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi rear projection tv
The tv has red and blue shadows/ghosting.
I checked the video settings and I can not adjust the red vertical lines or the blue. However in the advance setup I can adjust red and blue but the main vertical lines(big lines) I can not, if that makes any sense. Do I need to replace convergence IC's or is it something else? Thanks.
  • Anonymous Mar 31, 2014
    No Blue color vertical phase adjustment
    Problem Solver:
  • 6 Answers
Replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Posted on Aug 18, 2008
My Mitsubishi projection tv WS-A55 video isssue
Colored ghosts (red,green,blue) is convergence bad. If can't adjust from menu, then bad circuits. Call someone for approximate estimate.
Apr 20, 2010 | Televison & Video
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
Picture pretty good but vertical lines (shadows) and ghosts
You're going to have to be more specific. When you are messing with the convergence settings, are all of the crosshairs straight lines? Are they crisp or fuzzy? Can you successfully move the Red and Blue crosshairs up/down/left/right? Have you opened up the TV yet? I'll help you from there once we get some details.
Jan 05, 2009 | Hitachi 46UX50B 46" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
346 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
