Question about Baby Gear
Adult cushion subaru forrester sx my o9
Bought new vehicle and wife 5'4'' cannot obtain clear vision over large rear vision mirrors - looking for cushion to sit on - tried 80 mm thick from local auto shop around $30 it fixed vision but was not comfortable. Suggested suppliers please
    Scholar:
  • 125 Answers
A friend of mine had this problem! Pretty short lady, in a huge suburban. :) She went into a department store and found an accent pillow back in the home decor department that suited her to a tee. You might want to try this first, will be alot less than $30! (Plus, if it is not just perfect you can exchange it for another and try again!) :)
Posted on Aug 19, 2008
Removing the ignition cylinder in 2008 suzuki sx4
problem here is with a barrel for a lock , you need different keys to the rest of the vehicle
go to a locksmith and buy the barrel and keys and have the barrel reset to the existing key
that way you only have the one set of keys for the car and as the immobilizer is in the surrounds around the barrel it will not need reprogramming as you still are using the right key
Sep 10, 2016 | Gentex 2008 Suzuki SX4 - All SX-4 models -...
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
Circuit/System Description
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
? If greater than the specified range, test the signal circuit for a short to voltage.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
Feb 21, 2016 | 2009 Hummer H3
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
Replacing front shocks on a subaru forrester 06 model
go to www.automecanico.com and translate the website amazing with your browser and fix it.
God bless you
Jul 08, 2013 | Cars & Trucks
Trying to repair a 2007 Subaru Outback. The rear view mirror housing came apart from the base. I detached the base, but cannot get the ball attached to the mirror into the base. How do I re-attach the...
you dont. they make it so you have to get a new one. my wife broke our in our car and went on e bay and got one for a good price. sorry went through the same thing
Nov 30, 2010 | 2007 Subaru Impreza Outback Sport Wagon
How do i replace the rear view mirror in my 2003 subaru baja
This is the service procedure for a 2003 Subaru Forester, but should be the same: Rotate the mirror left or right about 90 degrees or as far as you can rotate it. There is a U-shaped clip that holds the mirror to its mount with a little U at the tip for pulling the clip out with needlenose pliers, etc. Buy new clip for reinstallation, about $6.10 from the dealer. There is a bladder in auto-dimming mirror that seem to burst with age and/or heat and a bubble of clear mirror with frosting appears that will move as you rotate the mirror. No recall that I have seen, but should be. Mine just went last week. $220 to replace at Winchester Subaru.
Mar 16, 2010 | 2003 Subaru Baja
For 2001 Forrester Subaru - Front Windshield Washer fuse
If it makes noise, it's not the fuse. Most likely the discharge nozzles are stopped up. Try blowing compressed air into them from the outside.
Dec 19, 2009 | 2001 Subaru Forester
Excessive fuel cosumption 1999 subaru forrester 2.0 turbo
Your mileage is just a little short of expected for this time of year. Winter driving does make mileage drop a bit. But your model should get closer to 24mpg in warmer weather. Tune ups and maintanance are the keys. Driving habits also make a huge difference. My Wife gets less mpg than I do. But I drive truck and am never in a hurry. I would just make sure all filters and fluids are new and good condition. Tire condition and alignment also play a large roll on MPG's. I hope this helps and have a great day.
Feb 21, 2009 | 1998 Subaru Forester
Clock removal
Go to Subaru-Clock.com for an easy-to-follow instructional.
Nov 20, 2008 | 1999 Subaru Forester
Baby Gear Logo
113 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Iron
Iron
Are you a Baby Gear Expert? Answer questions, earn points and help others
