Good day!
the only D.I.Y (do it yourself) procedures on any kinds of inverter is the battery
please check the voltage of your inverter BATTERY using multimeter tester (range in DC)
If the battery is 24vdc it should have a reading of not less than 23vdc.
if the battery is less than 23vdc its partially leak please replaced it
If the problem persist just add a comment
thank you.
The manual for aims1500 pure sine inverter is not available. The particular manual for this inverter is not not available.
Click the below link and check the inverter manual. You might find it helpful.
Click here: http://www.psui.com/pdf/75-1000-0001.pdf
Regards.
This guide should help.....
Please rate it when you are done reading it if it was helpful. :0)
Marci
since there is no manuel i need trouble shooting information. can you handle?
i have aims inverter without the manual. it has stopped inverting. it could be as simple as a fuse but it is nailed in place and i have to go thru some trouble to disconect everything. is there internal fuses and is there any other obvious reason that it is not working. need to trouble shoot or find a manual.
