The footswitch for bugera 6262 valve amp seems to have a logic problem. The clean channel leaves 'lead and reverb' leds lit on footswitch, pressing 'lead' lights the crunch channel on the amp... and reverb button selects 'lead channel' on both amp and footswitch led. very confusing
  • Anonymous Dec 07, 2008
    gosh man!
    i have the same problem with my 6262 footswitch
  • 4 Answers
Hi ! Check and make shure that the cord conections between the pc board on the backplate of the amp to the logic board are firmly pushed in there slots.
Good luck , Stefan from Sweden
Posted on Jan 05, 2009
SOURCE:
My Bugera Vintage 55HD has a problem: reverb is broken, doesn´t work. I need new modul BUGERA 94V BDM2 PCB822090 REVERB. Where I can buy it!
Look at the numbers on the reverb tank, type the numbers into fleabay and you will get a link to someone selling them. Otherwise, order one from Bugera.
Oct 07, 2018 | Bugera Music
Where can I get a schematic diagram of the Bugera 6262 Infinium Guitar Combo Amplifier?
Bugera - MUSIC Group
https://www.music-group.com/brand/bugera/home
Notice of Scheduled Maintenance. This is to advise you that our system will be unavailable on Saturday, January 9, 4PM - 6PM, SGT. Please plan accordingly.
Page 44: Bugera Users' Militia (for all things Bugera) @ Ultimate ...
www.ultimate-guitar.com/forum/.../index.php?t...
Ultimate Guitar Archive
Aug 17, 2011 - 100+ posts - ‎68 authors
I really like the cleans on this amp, and I don't consider using the overdrive.. so better tubes will ..... Its a 6262 212 combo ... 6262-212 INFINIUM 10/06/2011 ..... is there aschematic for this mod somewhere floating around? Page 48: Bugera Users' Militia (for all things Bugera ...
100+ posts
Jul 15, 2013
Bugera TriRec - First pricing (US) @ Ultimate ...
100+ posts
Apr 19, 2010
More results from www.ultimate-guitar.com
Rig-Talk • View topic - Bugera Amplifiers
www.rig-talk.com/forum/viewtopic.php?t=138566&p=1605914
Jun 14, 2013 - 50 posts - ‎12 authors
Jan 11, 2016 | Bugera 6262-212 Infinium Guitar Combo...
How do you use a four way footswitch
Need more info. What kind of foot switch and what are you hooking it up to. For guitar they are used for switching distortion to clean on 1 switch, one for reverb, one for chorus, and possibly 1 for bypass. All depending on the amp you use, and what effect the amp has built in it. Some amps only have clean and destortion which make the other channels on the footswitch useless. Hope this helps.
Dec 31, 2014 | Music
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
Broken input
The Bugera 6262 takes a standard 1/4" jack -- readily found online, music stores, or even Radio Shack. If you can solder, this is a basic fix, but will require that you pull apart the amp a bit. If you don't feel comfortable doing that, then I would suggest sending it in for repair. Try finding someone local to do this, rather than shipping it to the Behringer repair center. Best of luck!
Apr 04, 2014 | Behringer Bugera 6262 212
Changing channels by it self
Is this happening only with the foot switch plugged in? A bad cable on the footswitch is the most likely cause but there could also be a problem within the footswitch jack on the amp.
Aug 16, 2012 | Behringer Bugera 333212 120W 3 Channel...
I have a VOX AC15C1 amp and bought a VFS2A foot switch. The foot switch right LED did not come on and I sent it back for a replacement. The replacement foot switch came and the right channel seems not to...
That supposedly is the correct footswitch for the amp... there may be a defect in the amp. Contact the factory support about this problem. Make sure you are FULLY plugging in the plug as SOMETIMES they feel like they are clear in but they are not.
Sep 19, 2011 | VOX VFS2A
My new Bugera 333 212 combo has a weird "ringing" noise on the crunch channel. The noise can be heard on other channels too, but it is loudest on crunch. The noise is clearly mechanical, (it...
Microphonic tubes can be detected by tapping them lightly with a pencil. I cannot find if this uses a spring reverb, but if it does, vibrating the cabinet will get a clanky type sound from the reverb tank. This MAY use a digital reverb however which is immune to that. Next thing is to make sure your guitar can't "hear" the output sound of the amp because the strings can pick up the sound and resonate feeding back into the amp. You can detect if this is happening by quickly dampening the strings and see if ringing gooes away. You probably need 6 to 10 feet of clearance between the guitar and the amp OR put your body between the amp and the guitar. ALWAYS set sound level at safe levels. Get a sound meter and go no higher than 90 Db. I know a lot of near deaf musicians whose careers are near over because of hearing loss using too high level.
May 24, 2011 | Behringer Bugera 333212 120W 3 Channel...
How to replace the light in the standby switch on a bugera 333 head ?
I don't believe the standby switch has a light, unlike the main power switch.
I can also understand why they don't include one due to electrical considerations. This switch switches hundreds of volts instead of the line power that the main power switch does.
I know the switches look similar, but these are available both as lighted and unlighted which the standby switch is the latter.
Jan 31, 2011 | Bugera 333 120-Watt 3-Channel Valve...
1,683 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
