Question about Epson AcuLaser C2000 Printer
C2000 printer problem
My Epson Aculaser C2000 printer always shows serv req 023
Try to clean up the optical sensor on the left hand side. You have to remove left cover and find optical sensor and clen it up.
That's it. Schoul work fine.
Posted on Aug 28, 2008
Serv req 023
    Genius:
  • 1,447 Answers
Hi-
E 023 (2-23) Toner cartridge rack malfunction
try reinstalling the toner cartridges and make sure they are locked in to place.
Posted on Aug 18, 2008
My epson c2000 printer have a "service req e033"
Because the Epson AcuLaser Color 2000 was made for Latin America, there's not much information that I can give you concerning your Service Error Condition. All I can tell you is that the Service Request error # E033 is an Engine Related Service Call Error Message for OHP Detection Sensor Malfunction [abnormal condition]. Check to see if the windows on the OHP sensor are dirty and clean OHP sensor window and the OHP sensor reflective window. I'm sorry, but I can't even tell you where the OHP sensor is located, or anything else about it. If you cannot figure it out using your Owners Manual/Users Manual, you can always e-mail Epson Technical Support for possible help or advice, at epson.com
Mar 10, 2011 | Epson AcuLaser C2000 Printer
I have this problem with epson C2000 printer error code EO22 sometimes appear. Can somebody knows this problem.
E022 is a transfer belt rotation error, if it is happening every now and again it is a sure sign that it is on the way out. Try cleaning the belt & sensor, it may just be waste toner blocking the infra red sensor or preventing it from reflecting from the silver timing mark on the belt.
Feb 18, 2009 | Epson AcuLaser C2000 Printer
Error c1020
RAM Error. Replace it.
Jul 04, 2008 | Epson AcuLaser C2000 Printer
EPSON ACULASER C2000
Service Request/Error Code E022 is a malfunction of the transfer belt in its rotation. You can open the front cover and visually check. Pls try to remove the belt. There would be a small silver square on the edge, you can try cleaning this. If the cleaning works, well and good, if not, said belt must be replaced. Worst case scenario is a failed PWB-A Assembly (rarely).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 31, 2008 | Epson AcuLaser C2000 Printer
My pinter
The E020 error refers to a 2nd BTR transfer roller control gap malfunction.
You can try opening door AB and then reseat the roller (with the green levers) located in the door that comes down. Failing this you will need
an engineer to resolve the issue
Feb 28, 2008 | Epson AcuLaser C2000 Printer
PHOTOCONDUCTOR REPLACEMENT
Look at at the posts on fixyourownprinter.com in one of the posts I found this link to the service manual for the C2000. http://www.noizyboyz.com/pdf/epson.pdf You maight want to post it in the service manual section of FixYa.com for others to use. Good luck.
Aug 30, 2007 | Epson AcuLaser C2000 Printer
Epson C9100
Press and hold the four directional buttons as you turn on the power. Keep them held until the panel shows MAINTENANCE MODE. From here you will see the menu entry to reset the fuser counter
Aug 20, 2007 | Epson Aculaser C1100 Printer
Epson AcuLaser C2000 Printer Logo
315 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
