Question about Sylvania SRT2232S 32" TV
Please Help!!! My TV is stuck on the FOX Channel with no sound...there is a "1" in each of the four corners and 054-0.13 on the left side of the screen near top and 04 near bottom on the left side of screen as well. Doesn't respond to manual or remote(s). Help...Please? Also there is no re-set button on the back of the TV.
  • Anonymous Apr 08, 2009
    There's no sound on my Sylvania TV, there's a number "1" in each corner and the number 054-0.13 is diplayed on the screen. I unplugged the TV and it didn't do anything.
  • 3 Answers
Alright, I've got a solution now. using the menu button on the TV, scroll down to the "7F..." option (using the volume down button on the menu screen). Then turn off the TV and turn it back on. It worked for me at least, good luck!
Posted on Apr 08, 2009
  • 97 Answers
Newer model televisions usually have a combination of buttons you can press on the front to reset them to the factory defaults. contact the most senior person that works in the electronics dept. where you bought the unit, they will usually give you some insight without much, if any hassle.
Posted on Nov 28, 2008
SOURCE:
V chip
To release V-Chip code, you have to enter its service mode. Check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. It has details about how to enter, adjust and exit service mode, to many brand TVs.
Jul 04, 2013 | Hannspree HT09 28 in. LCD TV
Our 50" LG Plasma TV has become stuck on one
Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so, and allow it to make a hard reset, and check. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | Televison & Video
Stuck on auto set channel
Replace its main system memory IC. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 625 posts to different brand TVs.
Aug 19, 2012 | Emerson EWF2006 TV
My Lorex SV-01-RCV Wireless A/V instructions were lost in our move and I need help with the set up. Could you please help? I can not remember the correct connection.
You should have a 2-wire cable with Yellow, White and Red RCA plugs on each end.
The Yellow line is video out.
The White line is Left channel audio out.
The Red line is Right channel audio out.
Since your RCV only has two RCA jacks use the Yellow line for video and the White line for audio.
You should also have an "F-connector for co-axial cable.
If your TV set does NOT have audio and video jacks hook that to the co-ax antenna connector on the back of your TV set.
Set the RCV for either channel 3 or channel 4 and do the same with your TV set.
The RCV unit has four receive channels which must match up with the channel selected on the CAM or TX unit.
You can scan all four channels either by auto or manual.
If you only have one CAM or TX unit it probably doesn't matter which of the four you use unless you have a computer ROUTER which interferes with one of the four channels.
If so, select the 1, 2, 3, or 4 channel which has the least or no interference manually.
Bil Munsil
K1ATV HAM TV
Mesa AZ
Hams should be seen as well as heard.
Dec 30, 2009 | Home Security
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
HP PSC 1510 Scanner - Left side print is black (un-scanned)
Uninstall and reinstall the scanner utilities. Also make sure antivirus is disabled.
Thanks
Jan 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
"Weather Channel" OVERWRITED "OPTIONS"!
try going to the weather channel or send your wii to nintendo, it may just be a simple error, but i've never heard of such a problem before. You may want to consult 1-800-255-3700 (nintendo consumer service) for help
Jan 12, 2008 | Nintendo Wii Console
Son 1,mom 0
There may be a reset facility on the TV. Check the back, it will be a very small posh switch, size of ball-=point pen. If available it should restore to factory setting
Oct 06, 2007 | Sylvania SRT2232S 32" TV
Sylvania SRT2232S 32" TV Logo
187 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
