Question about Nikon Coolpix S4 Digital Camera
Flash seems like flash works when i take a pictures, but pictures are dark, as if flash didn't work at all. it looks like hte flash deploys too early. it still takes pretty good quality pictures outside when i don't need flash. thanks for any help
  • Anonymous Apr 07, 2009
    Impossible de changer le mode de fonctionnement du flash
I gave the lense part of the camara a moderate slap, and the camara has worked fine since. looks like a lot of people have the same problem. Most of the people call it black screen problem. the shutter gets stuck. Tap it a few times on the side of the lense part of the camara moving it from bright to dark objects back and forth.
good luck.
Posted on Aug 19, 2008
My Canon EOS rebel t3i's flash isn't working properly. It will flash, wait a second, then take the picture, making it come out very dark or completely black since the flash happens so early and I'm at
The multiple flashes are the camera attempting to autofocus on a subject that is too dark - it is trying to compensate for underexposure. Are you taking photos outside at night? Another thing to check is your lens. It is possible you have a poor connection between your lens and the camera which may be interfering with the focus and exposure (aperture) setting by the camera. Take and alcohol pad and wipe the contacts on both the lens and the camera body and dry them thoroughly with a lint free cloth. I have seen the oils from finger prints cause problems with contacts like this, so make sure they are clean and if you are in doubt, clean them twice. You should try to pop the flash open and not use the simple exposure settings on the mode wheel. If you are using the "easy" mode - stop. Use the portrait or night exposure setting. The other possibility is the processor in the camera is bad. If you have eliminated all the possible things then the camera is the culprit. I hope you have a warranty if that is the case.
May 10, 2017 | Cameras
Flash doesnt seem to work on amy mode. Takes great pictures in natural light but at night time all pictures are dark and red
My camera is Casio EX Z150, flash light always off. Please help me! Thanks you very much!
Dec 27, 2010 | Cameras
Flash/dark pictures
If this camera is new, take it back.
Apr 28, 2010 | Kodak EasyShare C613 Digital Camera
Pictures very dark even with a light meter
Digital cameras operate on a delayed shutter. Your Camera and flash are not synchronized. Try adjusting flash to a slower speed. Or the cameras Fstop value to get them insync.
If you half push the shutter the rangefinder and focus circuits kick in and will adjust to available light and give you your best picture. Do not ever push the shutter in one step. press it slightly to get the best focus and then push the last millimeter to get the picture!
Dec 29, 2009 | Fuji FinePix S3 Pro Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Dark monitor
Since the D40X is an SLR, (single lens reflex), it is not possible to use the LCD monitor to frame your pictures before they are taken.
To view what your images look like after you have taken them, you need to use the 'monitor/play' button marked with a rectangular box
Jan 31, 2008 | Nikon D40x Digital Camera
Canon eos 300d - image to dark
Try lithium batteries or rechargables in the 2500mah range,to me they seem to work best in a flash.
If you use alkalines,use a well known brand.But with alkalines,as they loose power it takes longer for the flash to recycle.
Also the monitor might need to be calibrated or adjusting brightness and contrast.
Mine sometimes does the same thing,I just use Photoshop to adjust it.
Jan 16, 2008 | Canon Digital Rebel / EOS-300D Digital...
Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Dec 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Pictures are dark, even when flash is being used
Press the FN button under the toggle on right side of LCD screen. You will see white balance on left. Toggle down to the "flash" symbol".  Should work a treat now. If not using flash go to FN again and raise ISO.(Don"t forget to go to Auto white balance again!!)
Sep 17, 2007 | Pentax *ist DL Digital Camera
Flash works but timing is off
If your camera is set properly there seems to be bad connection between shutter and the flash and you will have to send it in. I would though look again at the way your camera is set up for flash fotography.
Aug 13, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Nikon Coolpix S4 Digital Camera Logo
160 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
