Question about LG Shine KE970 Cellular Phone
Texting and taking off the t9 feature of assuming what im going to type
Ok so i txt alot and i just got this phone , put it in t9 entry mode and worked fine for the 15 txt's i sent , now for what ever word i put in it make a sentence for it
ex: type "hello" get "hello what are you doing today?"
I tried turning it off and I have to turn it off everytime i txt so it wont conflict w/ what im writing...how do u turn that off? for good
  • Anonymous Aug 18, 2008
    its called the t9 next word prediction how do i turn it off permanently?
You need to go to the t9 dictionary and delete that sentence. When you were typing a text one time you must of have typed that sentence and clicked add to dictionary so now when you type hello it will fill in that sentence. So if you were to go to your t9 dictionary you can delete that sentence and it will not do that anymore.
Posted on Jun 10, 2009
Sometimes it will pop extra words up like that for me, but i found that if you just ignore it and keep typing, they will go away. try it :)
Posted on Aug 18, 2008
SOURCE:
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
Can not get txt mode out of t9 a motorola w376g phone any ideas thanks
go to create sms message when opens hit center button and choose entry mode setup there you can pick and choose what options for txt you want IE: T9 iTAP or TAP
Oct 29, 2009 | Motorola Mobility W375 Cellular Phone
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Is it my imagination or is it true my new env3 does not support t9 or preemptive text?
From the front screen and keyboard:
(i.e. with the phone closed)
While entering a message, hit the main "OK" button for "Options".
Item #2 in this menu is "Entry Mode."
T9 is on this list.
Operating from the internal LCD screen and QWERTY keyboard:
Hit OK to get to main menu
Select "Messages"
Once in that menu, the left option key beneath the main LCD screen is "Settings" - hit that
On that menu, item #2 is "Entry Mode" where you can select T9
I have read of difficulties getting the enV3 T9 mode to add new "user" words that you might want to program into the T9 dictionary, so don't be surprised if you have trouble with that.
Oct 03, 2009 | LG enV3 VX9200 Cell Phone
I'm having problems changing the texting mode to T9
okay all you have to do is to go to messaging then hit reply or something then go to options then go to entry setup then go to primary setup and click on itap english and that t9
May 11, 2009 | Motorola Mobility RAZR V3
Predictive text on Samsung Propel
Well it's not so much a solution as it is an answer.
T9 is 9-key Texting. So it will only predict what you're going to type if you're using the 9-key triple tap mode of texting.
It WILL NOT intelligently select options of what it thinks you are typing on the QWERTY keyboard.
I've had this phone for less then a week & so far that would be my only suggestion for improvement. Otherwise, it's an awesome lil' phone for what I use it for.
Feb 19, 2009 | Samsung Propel A767 Cell Phone
Cant set T9 as the default entry method on LG cu920
yes you can set T9 as default on the Vu just go to the new message touch options and touch text entry mode and touch T9 Abc and that will become your default
Dec 24, 2008 | LG Vu CU920 Cellular Phone
Typing * symbol
This is a problem with LG's T9 autocomplete database that affects other LG phones as well.
I have a solution, but it's not for the feint of heart. It requires BitPim (bitpim.org). BitPim is a great app that does a lot more than fix this problem. It can be used to backup the data (calendar, contacts, notes etc) on your fone onto your own computer as well. Be warned though, it's not very user-friendly and it can be a hassle to get it set up at first.
You can learn more about BitPim from here.
Anyway, assuming you have BitPim working and talking with your phone (don't ask me about this part, see the link above)
Open BitPim, and look through the phone's Filesystem. This selection isn't shown by default. On a mac (and probably PC too), go to the view menu, then select "View Filesystem". "Filesystem" with a brown drawer icon will appear in the left hand column of the main window.
After the data is loaded from your phone, scroll down to "t9udb" folder in the second column. In the pane that loads, right click on "t9udb_eng.dat" and delete it. Restart your phone and the problem will be gone, and you can go back to using T9.
You will lose your saved t9 autocompletes, but you'll also get rid of this bug temporarily. This is a recurring problem, so you might have to delete this file every once in awhile. One way I've found to prevent this problem is to always type a space after a symbol. IE To type out "$260", I would type $ - space - CLR - 2 - 6 - 0
As annoying as this is, using this method is better than having to deal with all the weirdness that happens through regular use.
Good luck
Apr 06, 2008 | LG enV VX9900 Cellular Phone
Reset Symbol Recognition?
This happens because you have your enV text entry mode set to "Word". Undoubtedly, you did this for the same reason I did - to get T9 mode working when you text from the front keypad with the phone CLOSED, instead of from the QWERTY keyboard with the phone OPEN.
If you go to Messages->Settings->ALL Msg->Entry Mode and set it to Abc instead of Word, your problem should go away.
Mar 29, 2008 | LG enV VX9900 Cellular Phone
Predictive text on a motorola w375
Go to Messages -->Create-->SMS/EMS-->the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
Oct 24, 2007 | Motorola Mobility W375 Cellular Phone
LG Shine KE970 Cellular Phone Logo
524 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
