Question about Kenmore 63942 Dryer
Auto switch does not reach "OFF"
I do not know why my dryer brand Inglis doesn't reach "Off" when it run and I set Auto.
  • 943 Answers
Hi thanks for the question do your clothes come out dry but i would check the venting from the dryer to the outside very important thanks the appliance doc
Posted on Sep 25, 2008
My whirlpool inglis ele will not come on????
The Whirlpool Inglis has had a lot of problems with the door switch. Which would keep the unit from starting.
Jan 02, 2012 | Whirlpool Inglis IP8200 Dryer
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
My Inglis dryer has condensation on the inside of
normally condensation on the inside of a dryer is due to a pinched or plugged vent hose i have had this happen also when the dryer vent is very short and goes outside where the temperater outside is cold and moisture will condense on inside of dryer
if you live in a colder location there is a vent system
that you can install that will allow you to keep heat inside not reccomended for gas dryer the vent cap on the outside could also be missing the flap that stop air from going back into dryer hope one of these suggestions i a solution to your problem
Dec 10, 2009 | Whirlpool Inglis IP8200 Dryer
Inglis electric dryer will not start
Thers's a thermo switch that mounts of side of heating element can may be going bad or your vent is clogged with lint. try running disconnected from exhaust see if it runs normal
Aug 08, 2009 | Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Kenmore dryer no heat
check the thermal fuse to see if it's open which means blown(no continuity through it). check to see if heat element is broken somewhere. And if thermal fuse is blown then you'll also have to replace the thermostat switch and the high limit thermostat switch(located close to heat element).
Apr 05, 2009 | Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Parts for old inglis dryer
http://www.myapplianceparts.com/index.asp
These people can find a lot of hard to find parts. I know Inglis is owned by Whirlpool now, but dont know the age of yours, or how long ago this happened. Door switches were pretty much the same, so it shouldnt be to hard to find what you need. Let me know if you need any further help. Jim
Nov 21, 2007 | Dryers
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
