I have a magnavox 2004 51mp392h/17 prgection tv. The picture is crooked . The red & green are out of alignment. Can I fix this or should I replace it.
I have a magnavox t.v2004 but i dont have the control for the t.v and cant turn the t.v on .the t.v has light that saids standby
Posted on Feb 27, 2010
I have aquires a Magnavox rear projection tv. The picture is sharp but is in shades of red and pink. Obviously the green and blue are not working correctly. Any Ideas besides kicking it to the curb?
The tv have a problems known as a convergence pictures problems,the tv convergence board it is dead,that why tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv can be repair,by fixing the convergence board,by replacing 2 STK convergence ICS and some or all of it resistors too.Will fix convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors,to save this tv.
Jul 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51mp392h/17,that now has double vision (text is double,all images) there is also green, off red colors on the picture. Please help me the tv is 6 years old. should i throw it away or get...
No.Should cost u like $300-350 for parts and labors.Get it fixed any local tv shops can fixed this problems,very common problems for DLP CRTS tubs design projection tvs Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture colors lines R,G,B mis alignments,have pictures colors shadow or 3D pictures look alike.The tv convergence board must have it parts replace like 2 STK convergence ICS and some or all of it resistors to fixed the convergence board to solved convergence pictures problems.
Jul 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Magnavox Rear Projection 51MP392H/17 has ghosting issue ..red/green double hallow. TV is six (6) years old. any idea what's wrong?
If this happened suddenly and the red and green images are bowed in at the center of the top, bottom and both sides, one of the convergence amplifier IC's has failed. The part number is STK392-120. Make sure it is a genuine Sanyo brand replacement; there are a number of cheap imitations out there that do not last. Generally they cost less than $30 each.
Note: there are two of these in each TV. They are notorious for having a high failure rate, so I usually replace both. (FYI: each chip has three amplifiers. Each color gets two amplifiers, so one color uses an amplifier on each chip. That's why we usually see at least two colors go out of whack when this problem happens.)
I assume you have already tried a different video source (DVD, VCR, etc.) to rule out input signal defects. If the problem arose right after the set was moved, either the optical alignment was disturbed or (less likely) there is a stray magnetic field near the set that is causing problems (magnetron from a microwave oven?). There is a procedure (sometimes provided in the owner's manual) for adjusting convergence using the remote control that can fix minor alignment problems. If you want to gamble it is not a hardware failure, try it first along one edge of the picture.
If you cannot shift the red or green dots in the convergence pattern, stop immediately, and make a note of where and in what direction you tried to move the dots. Inability to converge the dots is a strong indication the convergence amplifiers are bad (that is their job - to keep the colors lined up with each other). You will need to undo any adjustment attempts after you replace the convergence chips and any fuses or resistors that got burned when they went out, so don't make too much extra work for yourself or your service tech.
Oct 27, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51 mp392H, red is out, what can we do?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Philips Magnavox 51MP392H Rear Projection...
Convergence wont align on Magnavox 51MP392H/17
You will need the original remote to perform a convergence touch up on Magnavox TV sets. If you are using the original remote - but still can't get it working - go back to the site where you purchased the tv repair kit and ask for their help
Feb 06, 2010 | Philips Magnavox 51MP392H Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture green and not clear, getting smaller, shutting itself off
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Mar 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Double images on half the tv
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Oct 27, 2008 | Sony KP-43HT20 43" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
