Question about Linksys Wireless-G WRT54G Router
Windows Visa slow Internet speed with WRT54G version 8
Hello everyone,
I have recently confgured my router (WRT5G v8) with my cable coonection and I always get slow signals on my laptop when I connect to my wireless. I have vista on that machine, but when I connect to the same wireless connection using my other laotop which has win xp, it receive 100% signals. I dont understand what did I do wrong with my router. Please note that I have flashed my router with dd-wrt latest firmware but still the problem is there. Also I would need to know how to connect to the wirelsee with statiic IP address. Can someone please explian this to me please. Thank you
  • AsadLala Aug 19, 2008
    Thanks for your stpes. But speed is still the same, Maybe it shows slow signals but the I am getting full speed. My next question would be how can I check the speed of my Internet speed, I mean is there online speed tester or tool to tell. Please help!!.
    Thanks,
    Asad
    Brigadier General:
  • 6,966 Answers
A possible solution that could address both the slow Vista and the static IP:
  • Pls go to Start, Control Panel, Network Connections;
  • Right click on your Local Area networking and click on properties;
  • Highlight Internet Protocol (TCP/IP) and then click on the Properties button;
  • Tick on "Use the following IP address;
  • Enter IP address > 192.168.1.5;
  • Enter Subnet mask > 255.255.255.0;
  • Default gateway > 192.168.1.1;
  • The DNS would be what your ISP has set;
  • OK, close.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
  • Louie  Role
    Louie Role Aug 18, 2008
    Hi again,
    The above is for a wired network. The posted "Right click on your Local Area networking and click on properties;" should be "Right click on your Wireless Network Connection and click on Properties;"
    Cheers.
  • Louie  Role
    Louie Role Aug 19, 2008
    Appreciate the postback/comment.
    Speed could also be affected by the antivirus/internet security used in the Vista machine. try to temporarily disable the antivirus/internet security and determine if there is a significant change in speed.
    There are a number of online DSL speed test, pls try doing a Google and select a test server nearest your current location.
Very slow connection speed
Basically the Wireless Internet always slow compared to wired ,also You can use the instructions in user manual,or get that from Online and then connect to Laptop,check any signal problem in wireless router ,better call the ISP to connect it,they will assist you,You can check the speed of the internet at here Scanmyspeed.com it will show Good Speed.
Jan 16, 2012 | Computers & Internet
Hello, I have an Acer Aspire 5742z laptop with Windows 7. The problem is with the wireless connection. It is really really slow. So slow that sometimes even gmail cannot be loaded. When I connect the...
Sorry to read about your problem, I hope this helps you out.
Wireless connections are slower, than using the cable. You may have a defective wireless router, or you PC is defective.
1. now in your home are you close to the router, and do you have strong signal strength.
i would take your PC to wi fi spot and see if its faster, if so, i would guess you wireless router is defective.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Acer Aspire 5742Z-4200 Notebook
I have a DI524 that was connected to my dsl modem before. Now I moved to a cable modem and connected the DI524 to the cable modem, but the wireless router doesnt work. help?
you have to confgure all the the setting in wireless configuration according to the cable connection then it will work.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
My laptop does not receive the router signal. The
Can you get other signals that are not your own?
If yes:
Reset the router back to factory default settings by using the tiny
reset button on the back/bottom.
If no:
Make sure your wireless card is turned on. Make sure you can see it in device manager.
Jun 17, 2009 | NetGear WGR614 54Mbps Wireless Router...
No comunication between router and cable modem.
this is because your PC is picking up the WRTG54G which is an internal signal booster (internal gateway) to the ROUTER ITSELF.
WRTG54G is in the middle like an interpreter.
The WRTG54G is not connect to ROUTER>
thus the laptop is not connected, like sprinkler attached to the end of a hose but the HOSE not attached to the water faucet.
turn OFF laptop. RESET WRTG54G (there is a small hole you can stick a pencil in there and hold down for 15 long seconds; UNPLUG power.
PLUB back in and hit auto config button.
let WRT54G pick up a new IP ADDRESS from router. once that is done turn on laptop and it should pick up a new signal with new IP address assigned to it by the WRTG54G.
Apr 26, 2009 | 2wire HomePortal 1100 Router...
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
Cannot activate wireless between laptop and Telkom Broadband.
Bring a wireless ROuter....
Now a dayz they have wizards which make very easy to confgure them.....
Nov 30, 2008 | Acer Aspire 3624WXMi Notebook
3com 3CRWER200-75 wireless router won´t connect to certain sites
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
Nov 03, 2008 | 3Com OfficeConnect Wireless Router
Router won't log into it's IP address online
Is your desktop getting an ip address from the router?
You said that you reset the router, do you mean turning it on and off or pressing the reset button?
Aug 03, 2008 | NetGear WGT624 Wireless Router
Linksys Wireless-G WRT54G Router Logo
139 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
