Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer ink How do I check my ink levels without reinstalling the printer ?
    Scholar:
  • 137 Answers
You can print a diagnostic test page as shown at HP's website here. The graphic between items 45 and 51 indicate the relative ink levels for the left and right cartridges.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Aug 18, 2008
SOURCE:
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have an epsonstylus office TX600FW printer. After replacing new catridges, my black ink is not all working, but ink levels showing full.
In most cases the printer driver software can have errors while being in use or is shut down.Also if the printer ink cartidges were replaced in the middle without the use of maintenance shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 16, 2011 | Epson Stylus 1520 InkJet Color Printer
My brother printer MFC 440cn won't print - a message 'unable to clean 4F' appears. How can I fix this problem without having to get it serviced.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Mar 15, 2011 | Computers & Internet
Epson D88 will not print, both red lights flash, message remove obstruction switch off and on. No change still 2 redlights flashing
The Lights can flash on an error and also iff the INK levels are down. You must check the ink levels and try to do a reset with printer software reinstalled.
Remvoe pinter from the PC, unistall and then reinstall to see if the printer shows the INK level exactly. If not replace INK cartridges to confirm.
Nov 16, 2010 | Epson Stylus D88 InkJet Photo Printer
Ink level .how do i check it ? specifics please
On the small screen move the highlight to Setup and press OK. Press OK again and the ink levels are displayed. The printer will not print if any of the cartridges is out of ink.
Jul 21, 2010 | HP PSC 950 All-In-One InkJet Printer
CHECKING THE INK LEVELS
just remove all the cartridges and you can see the level of ink .or you can go to printer service and maintenance option there also it show but that will not actual . So just remove and see the level..
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon BubbleJet i9950 InkJet Photo Printer
Ink monitor is lost
Try checking to see if your HP Digital Imaging Monitor is loaded & running. If you don't want to reinstall all the software (depending on wether you have broadband DSL) it's about 300Mb for XP or 43Mb for the bare drivers, then your only alternative would be the EWS program (if your going over ethernet), or the printers display screen. In your case I would check the whole software suite, a reinstall might help, but check first to see if all applicable HP program services are loaded & running (using the Task Manager).
Apr 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
132 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
