Product
Laundry Washer
Symptom
Error Codes
Sub Symptom
LE error code
Question
Locked motor error code.
Answer
LE
error code: This indicates a locked motor condition. Please check the
following conditions.
Large loads of laundry can put a strain on the motor causing the LE
error code. Try removing some clothing and restart.
Excessive suds can cause the LE error code. Make sure the customer is
using an HE (High Efficiency) detergent. They should decrease the
amount of detergent until the machine washes without suds. A few
bubbles can be expected. Areas that have �soft� water will usually need
to use less detergent.
If you suspect that excessive suds are the problem, let the machine
stand for 30 min (motor cool down) and then run a rinse and spin cycle
before restarting the load.
If these directions are followed and the code persists, the machine
will likely need service.
Posted on Aug 18, 2008
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Posted on Sep 15, 2009
Mar 26, 2014 | LG Washing Machines
Nov 02, 2012 | Washing Machines
Jun 30, 2011 | LG WM-2277HW Front Load Washer
Mar 03, 2011 | LG WM-2277HW Front Load Washer
Aug 15, 2010 | LG WM2277H Front Load Washer
Sep 14, 2009 | Washing Machines
Jun 10, 2009 | LG Washing Machines
Feb 25, 2009 | LG WM-2277HW Front Load Washer
Jan 17, 2009 | LG WM-1485FHD Front Load Washer
Dec 22, 2008 | LG WM2277HSW XL Front Load Stackable...
544 people viewed this question
