Question about Tomtom GO 720 GPS Receiver
Security lock I was wondering if there is a way to disable the security lock on the Tom Tom because it does not allow me to select an address to travel to while it is locked and stays locked untill I have reached my destination
  • Anonymous Oct 31, 2008
    I have exactly the same problem. Can anyone offer a solution?
Hi i had the same problem aswell, all you have to do is reset the factory settings,see if that helps.
Posted on Nov 18, 2008
SOURCE:
Cant connect to the internet..
Hi, What error do you get when connecting to the internet?
Anyways, Probably the Wireless connection your trying to connect to has a Network Security enabled on it.
Gaming consoles cant' access that type of Encryption, reason I do not know why but to be able to get wireless connection using your Nintendo DS you will need to disable the Wireless Network Security of your Wireless Router to be able to get Wireless Access using your Nintendo DS.
I also had issues with mine before and found out that disabling the Network Security will let me get Internet Access on my portable console.
Just Disable the Network Security this will allow you to get Internet Access on your Nintendo, for the Security of your Wireless you can get the MAC Address of each wireless device you have and input those MAC Addresses into the Router Settings to get Security and not allow other poeplt to gain access on your Wireless Internet.
I hope this Helps.
Have a nice day,
mvincentc
Jul 27, 2011 | Nintendo DS Lite Console
I don't know my WPA key
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Step 6 : IF the security mode is WEP then the key 1 will be your password
Regards
TOM
IF YOU WANT TO CHANGE IT
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable WPA - WPA2
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 30, 2010 | Belkin Basic Wireless Router
I FORGOT MY SECURITY KEY (PASSPHRASE)
Regards
TOM
IF YOU WANT TO CHANGE THE SECURITY
Step 7 : Enable 64 Bit WEP
Regards
TOM
Dec 28, 2010 | Belkin (F5D8231-4) Wireless Router...
How do you remove a security code from a wireless router?
Disabling wireless security key on the router. Just follow these steps:
Step 1: Access the router's web-based setup page.
Note: For Linksys default ip address 192.168.1.1: default password
Step 2: On the router's web-based setup page, click the Wireless tab then click the Wireless Security sub-tab.
Step 3:Click the drop-down arrow for Security Mode and select Disable and save settings.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
Car wont start / security lights flashing
if the security light is flashing try to shut all doors and using the key lock and unlock the drivers door from the outside. This should disable the security system and allow for regular operation. i hope this helps
Aug 19, 2010 | 1989 Buick Riviera
Wireless connection shows connected to Belkin Router. Cannot connect to internet. Some security setting i am missing?
Step 1: Connect your computer - Router ( Wired)
Step 2:Make sure that the wireless is disconnected in the laptop
Step 3:Open Router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 4:On the left under wireless click Wi- fi protected setup
Step 5:Leave the Password blank and click submit
Step 6:Disable it and click apply changes
Step 7:On the left under wireless click security
Step 8:Selected the security mode as WPA / WPA2
Step 9:Type a password in the blank field ( Pre Shared key or PSK )Make sure that the password is a minimum of 8 characters
Step 10:On the left under wireless click channel and SSiD
Step 11:Change the Wireless Channel to 6
Step 12:Change the SSiD to a different name
Step 13: Click Apply Changes
Step 14:Unplug the power cord from the router
Step 15:Plug it back After 15 seconds
Step 16:Now try to connect to the new network
Goto belkinrouters.blogspot.com for more ( Page is still under construction )
- Tom Riddle
Aug 13, 2010 | Belkin Basic Wireless Router
Change my wireless security to disabled
Please follow the steps below:
1. In the address bar of your Internet browser, type 192.168.1.1
2. It will prompt you for the username and password. Leave the username blank and then the password is admin.
3. Go to the Wireless tab.Then under Wireless Security select Disable.
Click the save settings button.
Dec 22, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Need To Secue Network
hello!
there are so many way you can secure your wireless network.
CHANGE THE SSID AND CHANNEL
1: Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
2: Click Wireless from the left menu
3: The settings to Wireless section of Router appear.Click Channel and SSID.
4: Change the Wireless Network Name (SSID) To identify your wireless network. To change the SSID, type in the SSID that you want to use in the SSID field and click Apply Changes.
5: Change the Wireless Channel to 1, 6 or 11. If there are other wireless networks operating in your area, your network should be set to operate on a channel that is different than the other wireless networks. Select channel from Wireless Channel drop-down menu. Click Apply Changes.
CHANGE THE WIRELESS MODE
Using the Wireless Mode Switch. This switch allows you to set the Router’s wireless modes. There are several modes. Note: Some modes may require firmware updates to be enabled. Select wireless mode from Wireless Mode drop-down menu. Click Apply Changes.
a) 802.11g only - this mode will allow only 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
b) 802.11g & 802.11b - this mode will let 802.11g- and 802.11b-compliant devices to join the network.
c) 802.11n & 802.11g - this mode will allow N1/draft 802.11n- and 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
d) 802.11n only - this mode will allow only N1/draft 802.11n-compliant devices to join the network, keeping out 802.11g and 802.11b devices.
e) Off - This mode will turn OFF the Router’s access point, so no wireless devices can join the network. Turning off the wireless function of your Router is a great way to secure your network when you are away from home for a long period of time, or don’t want to use the wireless feature of the Router at a certain time.
DISABLE SSID BROADCAST
This advanced feature will not broadcast your network’s SSID. Doing so will keep your network name hidden from computers that are scanning for the presence of wireless networks. To turn off the broadcast of the SSID, remove the check mark from the box next to Broadcast SSID, and then click Apply Changes.
ENABLE WIRELESS SECURITY
To access the security settings, click Security.
Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters.
a) From the Security Mode drop-down menu, select WPA-PSK (no server).
b) For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
c) Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
d) Click Apply Changes to finish. You must now set all clients to match these settings.
ENABLE WIRELESS MAC ADDRESS FILTERING
The MAC address filter is a powerful security feature that allows you to specify which computers are allowed on the wireless network. This list applies only to wireless computers. This list can be configured so any computer attempting to access the wireless network that is not specified in the filter list will be denied access. When you enable this feature, you must enter the MAC address of each client (computer) to which you want to allow network access. The Block feature lets you turn on and off access to the network easily for any computer without having to add and remove the computer’s MAC address from the list.
Setting up an Allow Access List
1. Click MAC Access Control.
2. Select the Allow radio button to begin setting up a list of computers allowed to connect to the wireless network.
3. Next, in the MAC Address field that is blank, type in the MAC address of the wireless computer you want to be able to access the wireless network, then click Add.
4. Continue to do this until all of the computers you want to add have been entered.
May 08, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Security lock and text issue
gostaria de saber qual a senha do protetor de senhas
Apr 23, 2008 | RIM BlackBerry 8700g Smartphone
Removing security from a wireless network
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Wireless Router (The default IP Address is 192.168.1.1).
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Wireless Routers password (The default password of a Linksys Router is admin) into the "Password" field.
  4. After the "Setup" Page loads, click on the Wireless tab.
  5. From the "Wireless" area, click on the Wireless Security sub-tab.
  6. When the "Wireless Security" area opens, select the Disable option for "Wireless Security" option
Apr 17, 2008 | Linksys Wireless-G WRT54G Router
Tomtom GO 720 GPS Receiver Logo
165 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
