Question about Sony Playstation 3 (PS3) Console
Hard Disk Corrupted
How do I fix this? I am pretty technical savy. However, how do I connect my ps3 hard drive to my computer to reformat?
Thanks!
  • 4 Answers
You can wipe the drive with your PC, but unless you use DOS you can not do anything else with it. The PS3 runs the FAT 32 system and can screw up your NTFS system on your PC if you try and run it with Windows or what not. I learned this from experience!!!! They have the external USB cases with protective sleeve and USB cable for $5 on eBay....brand new!!! Unfortunately the PS3 does not recognize the hard drive when connected using this device. Why, I don't know. It should as Jenkins said, it's like a big thumb drive. Good luck!!
Posted on Aug 20, 2008
  • detman08 Aug 20, 2008
    BTW, you most likely should just replace the drive!!
    Sergeant:
  • 359 Answers
BestBuy has a 2.5" SATA adaptor that has a usb interface that you just plug in your 2.5" SATA laptop hdd and use it to your computer like a huge thumb drive.
My coworker has one, it works great!!
Can you not reformat from ps3 menu? You should be able to do this, otherwise it sounds like your hdd could just be toast and need to be replaced.
Get a new one from http://www.newegg.com is one of the best places i have found.
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
How to fix a dead hard drive
Try a low level format. There is a strong possibility that your hard disk will no longer be able to perform normally even after a low level reformatting. Looks like a new hard disk is the answer.
Jan 04, 2010 | Maxtor Hard Drive
My files on my hard disk are corrupted whaat do i
You can try taking out the hard drive from the ps3 and hook it up to a computer that has SATA connections. Then copy the files to a flash drive. This way you can at least save the information from the hard drive.
At that point, put a new SATA hard drive into the PS3 and format the drive. Then at that point put the information that you saved to the flash drive onto the ps3 hard drive. Do this all in the computer after you format the new drive in the ps3 and then put it into the computer to copy the files from the flash drive into the new hard drive.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
The hard disks file system is corrupted.
If you can still access the PS3 menu, then reformat your hard drive by going to:
Settings > System Settings > Format Utility > Format Hard Disk
If you cannot, then you can try:
1) Remove the Hard drive, connect it to a PC and reformat it.
2) Download the latest PS3 operating system from the Playstation website and store it on a USB drive. Then insert the USB drive into the PS3 and start the PS3, and then install the operating system from the USB.
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
Hard disk corrupted
pettyjohnsco
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Mar 06, 2009 | Sony Playstation 3 (PS3) Console
Hard disk is currupted on play station 3 any way 2 fix this problem
Hello. The PS3 should say that it's corrupted and ask you to press X to reformat it. If it keeps doing that then you need to take it out and use a USB external drive case and reformat it on your PC. Just plug it in and click on Start > Computer > right click on the drive and click format.
Or you can just replace it and upgrade it at the same time.
I wish you the best of luck. Thanks!!
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
Hard drive corrupted try to restore but keeps saying hard drive corrupted can you help thanks
Hello. You need to replace the hard drive, or reformat your hard drive with your PC using an external USB connector.
Oct 06, 2008 | Sony Playstation 3 (PS3) Console
My ps3 hard drive is corrupted and a screen comes up saying the hard disk is corrupted it can be restored and then restarts and that screen keeps on coming up i want to know how to fix that problem
I see that you are getting the message saying hard disk is corrupted. The cause of the issue might be due to various reasons. to isolate and resolve the issue, I recommend you to perform the steps given in the below link:
http://www.ps3forums.com/archive/index.php/t-41928.html
If your not able to resolve the issue by your self
Please contact SCEA Consumer Services for technical assistance with a PLAYSTATION®3 computer entertainment system.
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00 - AM 6:30 PM PST
Please get back to me with observations and results because it is important that I resolve your issue in a timely manner. I would like to add that we value your precious time and would be here round the clock to serve you
Sincerely,
Geovanny
Sony Total Care
Mar 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
