Question about D-Link DFE-528TX Network Adapter
Trying to establish a port forwarding for my IP cameras
    New Friend:
  • 53 Answers
Port forwarding can be done using the routers configuration. Make sure that you have open your router page select Port Forwarding . Check this out for guidelines : http://portforward.com/
Posted on Jun 04, 2011
SOURCE:
How to Watch Security Cameras on the Internet (Port Forward IP Cameras)?
what sort of router is being used ?
are the cameras on static ip addresses ?
google search for
model of router and port forwarding
http://www.wikihow.com/Set-Up-Port-Forwarding-on-a-Router
Oct 19, 2016 | Cell Phones
Http 192 168
If you are trying to access the DVR server from outside your network, you need to use port forward, in that way you will use your DVR client to connect to the router's public IP, the router will be forwarding the port the video system use to the computer, just configure the computer's IP in the router's port forwarding configuration.
May 18, 2013 | Cisco Model EPC3925 8x4 Eurodocsis 3.0...
How to forward port for a IP camera on a Huawei 655b modem ?
You can't port forward on a modem. On a router, yes. You just need to set the a static IP on the camera outside of your DHCP range. Then select a port above 1024 and set that port to point to the static IP. You should only need to port forward UDP. Optionally you would want to setup a dyndns account since your public IP from your ISP is dhcp and therefore doesn't always stay the same.
May 30, 2012 | Computers & Internet
I am trying to get my servailliance camera hooked up via the internet. I am not getting a picture and I guess I need to set up a forwarding port on my router. How do I do this?
Look at the brand of router and model router and go to their web site. Down load / read the steps to log in to your router. Enter the URL link or IP , then user name and password. Look through the setup for a section that is labeled port forwarding. I've worked with several home consumer routers and their all web based and look pretty strange at first but study it and your see how to tell the router to forward a port to a specific IP. But that will only work it your computer always connects with the same IP on the router and that you always use that same computer to see your camera. Routers by default are DHCP and assign you an IP at random when you connect. Port forwarding would require you to also setup your computer to static IP, Meaning you MAC address would always be assigned the same IP, so the port forwarding would always be able to forward to the correct IP. Sounds much harder than it is. Your question sounds like you want to ensure the camera ip/port is passing through the router, so your home computer can see the video. Thats how you could forward a port to something. But if your wanting to see your camera from anywhere on the web then you'll want to make sure your router isn't blocking that port to the open WAN (wide area network). But I'd check your firewall on your computer FIRST>. Thats all a firewalls is for. Try connecting to your camera with your firewall / anti-virus software off for a test first. If it works then you need to be setting up your firewall on your computer and not your router. Firewall is usually part of your anti virus software and or, part of windows. Go to control panel, look for the security shield icon on XP and disable the firewall. You'll get some errors, but this is just for a test. I can't remember exactly the step for windows xp, but again look for help on your operation system of google it. Also don't forget about the lights on your router. Use them to help troubleshot. Went you plug the camera in, does the activity light come on? You can also have a bad cable...... good luck!
Apr 01, 2011 | Linksys Wireless-G WRT54G Router
How to configure the UPNP in panasonic camera?If we need access from the internet should we register in viewnet.com?
To access your camera from the Internet you will need to configure uPnP (or configure port forwarding manually) and register with some kind of dns service like viewnetcam (or know your home's external IP address assigned by your Internet Service Provider).
1. To configure uPnP on your camera, look in the network settings for an automatic network configuration option - this will trigger the camera to talk to your router using uPnP to set up port forwarding. The default for one camera is to use port 80 for the outside port and something like 192.168.1.253 for the internal network address (internal to your home only). uPnP will try to configure the second and third cameras to external ports 50000 or 50001. My router failed to configure the 3rd camera so I had to manually add a port forwarding option from my router's admin pages. To note, you can configure all port forwarding manually from within the router admin pages. Just list the internal network address to your camera (like 192.168.2.253) and specify a different port for each camera (like 50000 to 50000). You can then access your camera by typing in 192.168.2.253:5000
2. Then, you should register with viewnetcam.com. Adding your cameras on viewnetcam will give you access to them from outside your house without you having to know the IP address to your home network. You will simply type in your viewnetcam url with ":" and the port number (like username.viewnetcam.com:50000).
Note: When trying to access your camera from outside your home (or even pinging your router from outside your home), you need to know the IP address of your home. This is assigned by your Internet Service Provided and can change every time you reboot your modem. Services like viewnetcam keep track of the IP address to your home and update it automatically when it changes (your camera will communicate with Viewnetcam servers occasionally to update the IP address). All you have to remember is one constant URL (the viewnetcam url) and you can get to your cameras!
Aug 14, 2010 | Panasonic BL-C131 Network Camera
Port forwarding
As i remember all port forwarding was under Virtual Server configuration. But you need to check maybe web cam is using more then 1 port. Try to play with netstat to see, to which ports Connection establishing when you are connecting to cam.
Apr 19, 2010 | D-Link AirPlus DI-524 Wireless Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
Trying to port forward requests to the IK-WB21A webcam. From inside the house it works great. From outside, port forwarding port 8001 to 80 and I get NO response. Tried tcpdump and there is no response...
What are you using to view the Camera? Is this the only IP camera you are viewing/.accessing on the network? If it is not, are you using different IPs in the non-DHCP pool.
Typically you do not have to set-up port forwarding to gain access to the camera within the network. Normally port forwarding is set-up when you are outside your network and need to gain access to different applications/devices in your network using the same static IP address.
Let say you have a camera ip on 192.168.1.20.
You can connect to the camera with your web browser inside your network with the IP 192.168.1.20 (obviously), but if you have the camera set up to only be triggered on a specific port (other than the browser's default 80) let's say 100, then you would enter 192.168.1.20:100.
If the only thing on your network is the camera that you want to access from outside. you would setup in your router to route all incoming requests from port 80 (which is the web browser default) to the IP of the camera. Sometimes routers ask for a range just enter 80 to 80.
If the camera is working on a different port like 8001 then you would port forward 8001 to 8001 to IP 192.168.1.20. You would enter in your web browser (off-site) your static IP 69.132.54.176:8001. But I would suggest if the camera is the only thing you will be trying to gain remote access to, then leave it at 80 and set up forwarding for port 80 to the IP.
That way you can set up a free DNS service and not worry about paying extra for a static.
Nov 13, 2009 | Home Security
How do i install ip cameras so that i can see them over the internet? I have a dvr connected to my 2wire modem and I do have static ips
You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use.
Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
Sep 12, 2009 | 2wire HomePortal 1100 Router...
Port forwarding
try to use another port number aside from 8080, like 3000 or 5000. make sure that the ip address set on the router is the ip address of your camera (note: it should be set to static).
hope this'll help you
ciao
Oct 22, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
D-Link DFE-528TX Network Adapter Logo
61 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
