Question about Palm Portable Keyboard for PDAs, Palm m100, m105 (PDAPORKEYM101001)
Frist time user of a palm pda and need help setting it up and how come the docking station keyboard
I've been trying all day to set the key board up and have know idea what to do
  • 2,360 Answers
Dont stress it leave it after a time and try it........
Posted on Aug 09, 2010
Set date & time
Go to settings first , then set date and time.
Oct 18, 2008 | Palm Computers & Internet
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
When I press the shift key and the @ sybol I get " and vice versa, I know there a way of switching this back can anyone help?
dear malch652,
of course.. try to open the controlpanel and find the hardware properties on keyboard lay out. Try to update the keyboard driver and choose yourself (not configured by windows) select the 102 english keyboard lay out or 109keys japanese keyboard lay out (This is for Japanese made). And install it.
Any other way is to chage the regional and language setting on controlpanel and choose your location to match the keyboard input method and lay out according to your need. Don't worry, Windows are user friendly.. don't hesitate to explore, you can add, remove and anything with your keybord lay out.. After you master the keyboard, you can put the back to DEFAULT setting.
Jul 31, 2009 | Acer EZDock (LC.D0303.005) Docking...
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?) will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
I just bought a palm Z22 PDA. I used the AC charger to charge the Z22 but when I attempted to attach the USB synch cable I noticed that the plug is different from the plug on the AC charger. The USB...
I have concluded that the USB synch cable is not the correct one for my Palm Z22 PDA. There is only one point of attachment on the PDA and it is different from the plug on the USB synch chord. This was the last Palm Z22 PDA in the store so I think that the store clerk rounded up leftover parts and components of previous PDA kits and tried to make a complete set out of it. I am going to return the PDA to the store (Staples) in the next day or two.
Thanks for your offer of help. I will contact you again in the future if I need help.
Oct 15, 2008 | Palm Z22 Handheld
Delete key wierded out on me
The problem is that you have WordPerfect settings on.
Go to Tools > Options
Click the General tab
You need to uncheck the two items listed below:
-Help for WordPerfect users
-Navigation keys for WordPerfect users
Apr 25, 2008 | Computers & Internet
Docking station
What brand name laptop and docking Station???
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
115 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
