Question about Lexmark Color Z43 InkJet
Connecting printer to laptop
I have a printer that is now connected to a desktop computer. I would like to switch and/or have it connected to my laptop too. Do I have to get more cables to connect the printer to laptop or can I do something on the computer to make it possible?
  • Lexmark Master
  • 19,396 Answers
You need to install driver on laptop as well first.
If you want to connect the printer to two computers at the same time, you need either to plug/ unplug the usb cable each time.
Or you setup a network using a router and share the printer on the network.
Or you buy a printer servet or a printer switch and connect printer to both computer at same time, this is the best solution.
Got to a local retailer, explain what you want and get equipment (eg. printer server or printer switch) to share the printer between the two computer.
If you just need to install drivers on the laptop, use printer disk or follow instructions below:
Click right here.
A web page will open, select country, operative system etc., and click on download now loaction.
Chose to download the file in my documents when asked.
After downloading, find thefile, double click on the file, if you get in troubles ,then follow instructions below to reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Some Lexmark printer does not work on Vista.
Posted on Sep 11, 2008
Printer is linked to my desktop as well as my laptop. Works from desktop fine. From laptop, I have to touch my desktop keyboard and it prints, otherwise status says offline (laptop) HELP !!
If you connected the desktop with a hardwire connection (ethernet cable or usb cable) and the laptop is connected wirelessly, then the Desktop needs to be "awake" for the laptop to print. What I did was connect the printer to the network with an ethernet cable to the router, either wireless router or standard. Then you have a seamless connection for both computers independent of each other.
Dec 17, 2014 | Brother MFC-5860CN InkJet Printer
How do i change the language bak to English? And how do i print from my macbook laptop onto the printer
TO CHANGE THE LANGUAGE:
From the printer control panel, press the 'Spanner' icon.
Press the right arrow button, and then press OK
Press OK again.
Press the arrow buttons until the language that you want appears on the display, and then press OK.
If you are sure, press the right arrow button, and then press OK to change the language.
To print from your macbook laptop you may have to install additional software onto your laptop from the installation CD. Insert the CD and wait for the 'Welcome' screen to appear. (Note if the 'Welcome' screen does not appear after a minute, then click the CD icon on the desktop). Double click 'Install' and follow the screen instructions.
Some additional notes that may apply to your machine(s):
If the printer is connected to a desktop computer through the rear USB port and you decide to connect a laptop computer to the printer through the Quick Connect laptop port, then the Quick Connect laptop port connection overrides the rear USB port connection. The active print jobs on the desktop computer may be cancelled. Pause or cancel active jobs on the desktop computer before switching between ports.
To summerise:
Pause or cancel active jobs on the desktop computer.
Connect a USB cable to the laptop computer and then to the Quick Connect laptop port on the front of the printer.
Warning-Potential Damage: Do not plug in or remove the USB cable from the Quick Connect laptop port while a memory device is being accessed by the printer.
If you have not yet installed the printer software on your laptop then install it now.
Hope this helps
Jul 14, 2011 | Lexmark X6675 All-In-One InkJet Printer
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Im trying to set up wired computer desktop to share my new s605 to my sons laptop wireless...do i need to use the CD enclosed with the printer and put it in my sons laptop to install the printer on his...
Yes you need to setup the printer as a shared printer using the printer driver CD.
Your shared printer and computer would need to be on your LAN and connected to a wireless router. The laptop will connect to the shares printer via the wireless router and LAN cable to the computer with the shared printer.
Please click on this link and follow my instructions to setup the shared printer.
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Jun 03, 2011 | Lexmark Interact S605 All-in-One Color...
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
How do I connect 2 computers to one HP LaserJet 1300 printer?
on your desktop go to printers and share your printer. then from your laptop go to printers click add new printer. then choose a network printer and click find or search to find the printer conencted on your pc. the pc has to be turned on in order to print
Jan 21, 2010 | HP LaserJet 1300 Printer
Want to share 922all in one on xp desktop with laptop using Vista
I have a network running both an XP computer & a Vista computer. What I had to do after connecting them both to the router was make an internet connection with 1 computer, turn on the printer so everything the network was going to share was powered on; then run the network wizard on both computers. Once I did this the computer that the printer is not physically connected to installed the printer driver. Once this entire process was completed we had internet on both computers as well as both computers being able to send jobs to the same printer. Has worked great for over a year. Hope this helps you out.
Mar 16, 2009 | Dell 922 All-In-One InkJet Printer
Desktop won't connect with printer connected to laptop
Make sure both computers can share files and can ping each other, if not, it's just a firewall issue. Try to disable your firewall first.
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Trying to connect share printer w/Vista
If you connect the printer to the desktop computer and enable file and printer sharing on that computer. You will then need to go into printers and faxes and share your printer. Then go to the laptop and browse the network so you are looking at the desktop computer. You should see a folder that says printers. Open the printers folder and you should see the printer you just shared. Double click on it to install the shared printer on your laptop.
Now when you print from the laptop, you will print to the shared printer that you just installed (you may have to select it from the printer list). That will send the print job through the network to the desktop and the desktop will send it to the printer (the desktop will need to be turned on for you to be able to print).
If you don't want to have to leave your destop turned on just so you can print, you should look at a print server for your printer. That will connect the printer straight to the network. Then both computers will print to the printer over the network.
May 28, 2008 | Linksys 4-Port CPU Switch 843734000836
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
Lexmark Color Z43 InkJet Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
