Question about Akai LCT2785TA 27 in. LCD Television
Coaxail Hi I tried to pull out a cable that was connected to my coax connection on my tv and the cable was cross threaded and I pulled to hard and the etire cable came out including the piece connected to my tv! Is this going to be a big problem to fix?
  • 525 Answers
This piece is called RF connector. This problem is not so big but it will cost you some $35 for to replce it.
Find a technician near your location , he will help you.
Posted on Aug 28, 2008
Panasonic DMR - HW100ebk.......... with both coax
So you have looped the coaxial through the Panasonic to the TV and have a HDMI from the Panasonic to the TV, right. When you turn on the DMR select the appropriate HDMI connection with the TV remote and you will be OK.
Oct 11, 2013 | Televison & Video
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
Sep 07, 2012 | GE 25GT240 25" TV
Pulled plug (antenna connection) out from the back of the TV set it broke off tried to fix it and now lost the threaded male end can this be fixed & how much the dvd works great,ser#057340809675 upc#7...
You can buy the male coax threaded terminal at Radio Shack or Home Depot...some Walmarts carry it too. You can do it yourself, just follow the instructions on the package. You will have to strip the plastic shiething off the cable a little with a knife.
Feb 08, 2010 | Orion VR213 VHS VCR
The attachment point for the coax cable was pulled off-broken off
You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
Dec 03, 2009 | Sharp 27H-S60 TV
How do i connect catv conveter onto a tv
There are a few ways to do that. It depends on the connections the tv and the converter have.
1st way is to take a coax jumper from the box to the tv coax input. Coax meaning cable wire that screws on like the wire coming from the outside to the box.
2nd way is to use red yellow white tri-cable, or audio visual cables if the tv has them as inputs, the color of the ends is the same as on the input ports.
3rd way is to use a component cable. These are the 5 connectors bunch which have 3 video and 2 audio and go to the same colored component video in.
Jul 07, 2009 | La Crosse Radio Controlled Atomic Clock
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
I'm trying to hook up my vcr to my digital box and tv. I think that I have the connections right but when I try to record a tv channed it doesn't record. What am I doing wrong? Or how do I hook up my...
Make sure your VCR is on channel 3 or try channel 4. Also, make sure your VCR is set to VIDEO or VCR and not TV.
A better way to do this is to connect the cable box to the VCR using the composite cable (yellow/red/white) cable. Then, connecting the cable box to your TV with component cable (red/greenblue) cables. This will only work if your TV has component in. If not, then connect the VCR out composite (yellow/red/white) to the TV. Or use the coax cable from the cable box labeled TV/VCR right to your TV. Make sure your VCR is set on LINE1 or LINE.
May 02, 2009 | Memorex MVR2031 VHS VCR
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Coax that looks like RCA?
There is a distinct difference between coax and phono (rca) cabling. Coax, sometimes called RF, is a cable that carries audio and video at the same time, what we call a "modulated" signal. RF connections look as if they are threaded on the chassis of your TV or VCR etc. A lone "Phono" cable moves either audio or video, but not both at the same time, unlike coax.
If you are attempting to patch RF, your cable must be coax at both ends.  Hope that helps.
Jan 07, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
Toshiba tv 32ax60 3 thin wires disconnected
belive your referring to rf converter assembly. entire unit can be replaced  or if threaded end pulled out can be repaired. dont understand 3 wires unless worked on previously. avg shop prob min bench to repair. .
Dec 02, 2008 | Toshiba CX36H60 TV
Akai LCT2785TA 27 in. LCD Television Logo
44 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
