Question about Philips MX3700D Digital Surround Sound Receiver System System
Philips Surround Sound w/ DVD and VHS
My question is that - Last week I was going to play an DVD but all of the sudden the part that accepts the dvd inside hestitated and wouldnt close then i forced it in then the entire system shut down. Now I'm just wondering would it be cost effective to take to an Repair Shop or just buy an New one?
  • 36 Answers
Well the dvd mechanism is probably broken now and that is the reason the system shutdown, philips can offer you a out of warranty exchange price to get it exchanged but they probably don't carry repair parts for this unit anymore, I would buy a new system
Posted on Aug 19, 2008
    Sniper:
  • 51 Answers
You better to buy a new Player.
Posted on Jan 09, 2009
Toshiba V231 UK VHS manual is lost. Since last week I disconected and then replaced to my Toshiba TV. I can not Autotune it back to play VHS recvordings. I get sound but the tracking just flickers up the...
I believe you are using a RF wire Connecting a VHS, then searching TV station is an old way. I would recommend you use a RCA wire. By so doing, you won't need to tune any station on your TV. All you need to is select Source (AV) on the TV and the VHS would automatically display on your TV.
Below is what the RCA cord looks like:
The yellow stands for video (display), while the red and white stands for audio left and right (sound).
Purchase this cord from any electronics part store within your area, it's not expensive at all.
Look at the back of your TV, connect the yellow cord to "Video IN", connect the red and white to "Audio IN". Then connect the other end of the cord to Yellow: "Video OUT", and red or white to "Audio OUT", at the back of the VHS.
After the above connection, turn on the VHS, insert a tape, and press play. While the VHS is play, turn on the TV, select Source (AV) on your TV and your VHS will start displaying and you will hear sound.
I hope the above is clear. If you need further assistance, please let me know.
Regards.
Sep 20, 2011 | Toshiba Televison & Video
Have surround sound only when play dvd..
if you have a sat/cable box it may have audio outputs that you can connect to the input of the surround unit or if your tv has an audio uotput it can be connected to the surround unit. The audio outs of the tv may or may not adjust with the tv volume. This will not produce a true surround signal because th tv does not output a true surround signal. But yo can adjust the surround unit to get a nice sound.
Jun 26, 2009 | Philips SoundBar DVD Home Theater with...
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Jan 07, 2009 | Audio Players & Recorders
VCR Not Accepting Certain VHS Tape
I had this happen once and all I did to correct it was to fast forward it just slightly or manually wind it past the leader strip (the clear or white part at the beginning). To do it manually, there is a small hole you must insert a toothpick (or something else as small) to push the pin in and then advance it with your finger while holding the pin in. Hope this helps.
Oct 15, 2008 | Philips Magnavox DVD/VCR Dual Player
VHS picture won't work but DVD is fine
VHS part of your machine got video head dirty / clogged. use good quality VHS head cleaning cassette to see picture again.
Sep 30, 2008 | Philips Magnavox DVD/VCR Dual Player
VHS side doesn't have pictures
the connection from your player to TV is only single output not separated DVD and VHS. If there is picture when used on DVD then you should be having problem with your VHS player. Question.... is your unit new? Is this the first time you encounter this problem? what is the brand of your player?
Jun 28, 2008 | Televison & Video
No sound Problem - Philips VR550 VHS VCR
If your pre-recorded tapes also play without sound, then check the scart lead is in straight.
If not, then it's more likely to be a dirty audio head.
Try a VHS head cleaner tape.
May 20, 2008 | Philips VR550 VHS VCR
Philips DVDR 3380
the laser mechanism must be changed
Jan 17, 2008 | Philips DVDR3380/05 DVD Recorder
VHS to DVD
You would need a tv tuner on your pc's graphics card, then you could hook up the vcr with an adapter and record the vhs to your pc, then you would have to burn that to dvd. I don't think you can go directly from vhs to dvd, without an actual device (where there are those that do that.) ADS Tech's $100 DVD Xpress DX2. The DX2 has a video converter that can accept composite or S-Video signals. It converts these to digital format and sends them to a PC via a USB connection. It comes with Ulead VideoStudio 9 SE DVD software for editing the video.
Dec 16, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips MX3700D Digital Surround Sound Receiver System System Logo
335 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
